Inverting and non-inverting gate/mosfet driver
Can some1 tell me what is the difference for USAGE of inverting and non inverting mfet drivers? I ordered couple of MCP1406 to drive low side N channel BUZ11s, while i drive high side P channel 27PO6 whit a bjt transistor?
Thank sfor any help
Not sure I know what you mean, I am not sure you know what you mean.
You use inverting drivers when you want an inverting driver and non inverting when you want a non inverting.
You know what one you want when you design the system. If you don't then you shouldn't be designing a system.
It is like asking "when should I choose to buy apples and when to buy pears".
I found this application document that explained which mosfet to use depending of the applications that may help you to answer your question. It helped me a lot whe I was learning how to use mosfets.
attached it is the document.
working with mosfet.pdf (331 KB)
I thougt that invert/noninvert drivers correspond to particular mosfets, but thanks to this attached application note i see it is al ldown ot my circuit design. Thanks both for help.
