Inverting Potentiometers output
Where in this code do i insert this libraries command that inverts a potentiometers output?
#include <Control_Surface.h> // Include the Control Surface library
// Instantiate a MIDI over USB interface.
USBMIDI_Interface midi1;
// Instantiate CCPotentiometers
CCPotentiometer potentiometers[] {
  {A0, 0x4A},
  {A1, 0x2A},
  {A2, 0x5},
  {A3, 0x13},
  {A6, 0x14},
  {A7, 0x15},
  {A8, 0x16},
  {A9, 0x17},
  {A10, 0x19},
  Control_Surface.begin(); // Initialize Control Surface
  Control_Surface.loop(); // Update the Control Surface
and the command according to the documentation found here, Control Surface: CCPotentiometer Class Reference is
void 	invert ()
Can you give more information please?
What is this Control_Surface?
What potentiometers are we talking about?
What is the setup in hardware?
What should this setup do?
Hi, @sloan666
Welcome to the forum
What model Arduino are you using?
This may help;
Tom.... :smiley: :+1: :coffee: :australia:
Add the following to your setup():
for (auto &p : potentiometers)
  p.invert();
this worked perfectly!
Thank You!
