Inverting Shift Register outputs in Arduino IDE.
So finally i hooked up a 74HC595 Shift Register, to a 7 Segment display, but it is a common Anode type, i hooked it up like normal LEDs and used the following code to display the letter "A":
int dataPin = 2;        //Define which pins will be used for the Shift Register control
int latchPin = 3;
int clockPin = 4;
    pinMode(dataPin, OUTPUT);       //Configure each IO Pin
    pinMode(latchPin, OUTPUT);
    pinMode(clockPin, OUTPUT);
        digitalWrite(latchPin, LOW);          //Pull latch LOW to start sending data
        shiftOut(dataPin, clockPin, MSBFIRST, 0x11 );         //Send the data
        digitalWrite(latchPin, HIGH);         //Pull latch HIGH to stop sending data
       delay (1000);
As you can see Hex 0x11 means 00010001, i had to invert in manually, is there anyway i can do it in software, ie the 0's will become 1's and vice versa.
Use the bitwise invert operator: ~ (tilde)
shiftOut(dataPin, clockPin, MSBFIRST, ~data ); //Send the data, inverted
It doesnt seem to work :~
Maybe my question isnt clear i mean to say if a byte is: 10101010
I want it to be: 01010101
Cross posted. (in Displays).
Pete
adilmalik:
That's what the '~' operator does. Perhaps you have some other error.
Read my answer in your crosspost in "Displays".
Pete
