Inviare dati da Arduino su una pagina del mio sito web
/*Master*/
#include <Adafruit_CC3000.h>
#include <SPI.h>
#include "utility/debug.h"
#include "utility/socket.h"
#include <Ethernet.h>
#include <EEPROM.h>
// These are the interrupt and control pins
#define ADAFRUIT_CC3000_IRQ   3  // MUST be an interrupt pin!
// These can be any two pins
#define ADAFRUIT_CC3000_VBAT  5
#define ADAFRUIT_CC3000_CS    10
// Use hardware SPI for the remaining pins
// On an UNO, SCK = 13, MISO = 12, and MOSI = 11
Adafruit_CC3000 cc3000 = Adafruit_CC3000(ADAFRUIT_CC3000_CS, ADAFRUIT_CC3000_IRQ, ADAFRUIT_CC3000_VBAT,
SPI_CLOCK_DIVIDER); // you can change this clock speed
#define WLAN_SSID     "WLAN"         // cannot be longer than 32 characters!
#define WLAN_PASS     "pass"
// Security can be WLAN_SEC_UNSEC, WLAN_SEC_WEP, WLAN_SEC_WPA or WLAN_SEC_WPA2
#define WLAN_SECURITY   WLAN_SEC_WPA2
#define LISTEN_PORT           7    // What TCP port to listen on for connections.  The echo protocol uses port 7.
Adafruit_CC3000_Server echoServer(LISTEN_PORT);
//Variable reset millis()
extern unsigned long timer0_millis;
/* Casa mia */
byte subnet[] = {
 255,255,255,0};
byte gateway[] = {
 192,***,*,*};
const char server[] = "www.cormaz.altervista.org";  //Insert your website
Adafruit_CC3000_Client client;
const unsigned long
 connectTimeout  = 15L * 1000L; // Max time to wait for server connection
void setup(void)
 Serial.println(F("Hello, CC3000!\n"));
 /* Initializes the module */
 Serial.println(F("\nInitializing..."));
 if (!cc3000.begin())
   Serial.println(F("Couldn't begin()! Check your wiring?"));
   while(1);
 Serial.print(F("\nAttempting to connect to "));
 Serial.println(WLAN_SSID);
 if (!cc3000.connectToAP(WLAN_SSID, WLAN_PASS, WLAN_SECURITY)) {
   Serial.println(F("Failed!"));
   while(1);
 Serial.println(F("Connected!"));
 Serial.println(F("Request DHCP"));
 while (!cc3000.checkDHCP())
   delay(100); // ToDo: Insert a DHCP timeout!
 /* Display the IP address DNS, Gateway, etc. */
 while (! displayConnectionDetails()) {
//Starts listening for connections
 Serial.println(F("Listening for connections..."));
 uint32_t ipAddress, netmask, gateway, dhcpserv, dnsserv;
 if(!cc3000.getIPAddress(&ipAddress, &netmask, &gateway, &dhcpserv, &dnsserv))
   Serial.println(F("Unable to retrieve the IP Address!\r\n"));
   Serial.println(F("IP Address obtained!\r\n"));
   uint8_t macAddres[6];
   Serial.println(ipAddress);
   if(!cc3000.getMacAddress(macAddres))
     Serial.println(F("Unable to retrieve MAC Address!\r\n"));
   else{
     Serial.println(F("MAC Address obtained!\r\n"));
 Serial.println("Beginning ... ");
 delay(2000);
void loop(void)
 unsigned long t;
 String strURL;
 unsigned long ip;
 int i = 0;
 double temp;
 double hum;
 char name[6];
 Serial.print("WebSite: ");
 Serial.println(server);
 //Hostname lookup
 Serial.print(F("Locating Web server..."));
 cc3000.getHostByName((char *)server, &ip);
 Serial.print("IP: ");
 cc3000.printIPdotsRev(ip);
 Serial.println("");
 //Connect to numeric IP
 Serial.println(F("OK\r\nConnecting to server..."));
 t = millis();
 do {
   client = cc3000.connectTCP(ip, 80);
   Serial.println("Success");
 } while((!client.connected()) && ((millis() - t) < connectTimeout));
     resetMillis();
 char* idwf;
 char* twf;
 char* hwf;
 sprintf(idwf, "%f", name );
 sprintf(twf, "%f", temp );
 sprintf(hwf, "%f", hum );
 strURL = "GET /g********e.php?id=";
 strURL += 1;
 strURL += "&temp=";
 strURL += 27;
 strURL += "&umid=";
 strURL += 76;
 if (client.connected()) {
   Serial.println("Loop connected");
   client.print(strURL);
   client.println(" HTTP/1.1");
   client.println("Host: www.cormaz.altervista.org");  //Insert your host
   client.println("User-Agent: arduino-ethernet");
   client.println("Connection: close");
   client.println();
   client.stop();
   Serial.print(strURL);
   Serial.println(" HTTP/1.1");
   Serial.println("Host: www.cormaz.altervista.org");  //Insert your host
   Serial.println("User-Agent: arduino-ethernet");
   Serial.println("Connection: close");
 delay(60000);
  Tries to read the IP address and other connection details
bool displayConnectionDetails(void)
   return false;
   Serial.print(F("\nIP Addr: "));
   cc3000.printIPdotsRev(ipAddress);
   Serial.print(F("\nNetmask: "));
   cc3000.printIPdotsRev(netmask);
   Serial.print(F("\nGateway: "));
   cc3000.printIPdotsRev(gateway);
   Serial.print(F("\nDHCPsrv: "));
   cc3000.printIPdotsRev(dhcpserv);
   Serial.print(F("\nDNSserv: "));
   cc3000.printIPdotsRev(dnsserv);
   return true;
//Reset millis()
void resetMillis() {
 cli();
 timer0_millis = 0;
 sei();
Però non capisco perchè ma non mi carica i dati nel database.
Se invece scrivo:
cormaz.altervista.org/g********e.php?id=1&temp=27&umid=76 HTTP/1.1
Il dato viene correttamente caricato.
PS: alla voce Host ho messo il sito, ma ho provato anche con “server” e “localhost”, ma non funziona lo stesso.
Potreste aiutarmi?
Ciao, grazie.
Ragazzi salve, scusate per sbaglio avrò cancellato la parte di sopra. In pratica voglio inviare dati da Arduino a questa pagina: Serra domotica - Blog Co.R.M.A.Z. Sopra ho postato il codice da me scritto.
Ragazzi nessuno può aiutarmi, io credo che il problema sia il tipo di host
Se invece scrivo: cormaz.altervista.org/g********e.php?id=1&temp=27&umid=76 HTTP/1.1
scrivi dove? sulla barra degli indirizzi?
qui hai un esempio di come va fatta una richiesta al server remoto sia con metodo GET che con metodo POST http://playground.arduino.cc/Code/WebClient
Si, nella barra degli indirizzi. Avevo già visto questo esempio. Purtroppo però ancora non funziona.
