IOS and Android Compatible Bluetooth Data Logging
hello all I am working on a project where I have to find environment's temperature, pressure and humidity using arduino and Bluetooth. for this I am using bleduino, DHT22 temp. and humidity sensor and BMP180 pressure sensor. I want my project to be compatible with both IOS and android.
can you all please help me to tell if I am using the correct Bluetooth module i.e.bleduino or not or I have to use another module such as nrf8001 or HC-06 ?? Its urgent =( since I have to make the report on which Bluetooth module I will use in my project.
Thank you in advance. Please reply soon
Moderator edit: Sensible topic title.
I think any slave Bluetooth module should work, but I believe for IOS there is a restriction about Serial data communication over Bluetooth (there is no restriction on Android).
I just do quick search on google check it out (It seems BLE 4.0 modules can talk IOS)
http://makezine.com/2012/03/19/bluetooth-4-0-from-arduino-to-iphone-no-jailbreaking-no-mfi/
Thank you I also searched about Bluetooth module and I found BLE SHIELD and nrf8001 adafruit. Both are compatible with IOS and android.
dushyant Please change this topic Header to more specific one like "IOS and Android Compatible Bluetooth Data Logging"
OK I have enough information about IOS - Arduino Bluetooth integration. As reference, for those who want to communicate with IOS over Bluetooth should use Bluetooth 4.0 modules (aka BLE - Bluetooth Low Energy). Not cheap ones like HC-05, HC-06 or anything other than Bluetooth 4.0.
http://www.mkroll.mobi/?page_id=386
I changed the topic..... :P how about BLE Shield
http://redbearlab.com/bleshield/
this is also compatible with IOS and android and also nrf8001 adafruit
http://www.adafruit.com/products/1697
have a look at it
This BLE Shield is some what similar to the link which u have send me.
