Iot_api_client - AttributeError: module 'iot_api_client' has no attribute 'DevicesV2Api'
I am trying to list the properties of a Thing using the Python API, but I'm having a bit of trouble.
I took this code from here: https://pypi.org/project/arduino-iot-client/
    # Now we setup the iot-api Python client, first of all create a
    # configuration object. The access token goes in the config object.
    client_config = iot_api_client.Configuration(host = "https://api2.arduino.cc/iot")
    # client_config.debug = True
    client_config.access_token = token.get("access_token")
    # Create the iot-api Python client with the given configuration
    api_client = iot_api_client.ApiClient(client_config)
    # Each API model has its own wrapper, here we want to interact with
    # devices, so we create a DevicesV2Api object
    api_instance = iot_api_client.DevicesV2Api(api_client)
    # Get a list of devices, catching the specific exception
    try:
        resp = api_instance.devices_v2_list()
        print("Response from server:")
        print(resp)
    except ApiException as e:
        print("An exception occurred: {}".format(e))
And when I run it I get the following error:
AttributeError: module 'iot_api_client' has no attribute 'DevicesV2Api'.
Thanks!
Solved :slight_smile:
I downgraded to version 1.4.4 (pip install arduino-iot-client==1.4.4)
Hello,
Has anyone managed to run the program without downgrading to version 1.4.4?
Thanks!
