I am working on IoT Based Patient Health Monitoring System using ESP8266 and Arduino and I got an error that
warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
if(esp8266.find(">"))
exit status 1
'class Timer' has no member named 'every'
So i changed the string to char but got error
request for member 'length' in 'cmd', which is of non-class type 'char'
#define USE_ARDUINO_INTERRUPTS true
#define DEBUG true
#define SSID "*****" // "SSID-WiFiname"
#define PASS "*****" // "password"
#define IP "184.106.153.149" // thingspeak.com ip
#include <SoftwareSerial.h>
#include "Timer.h"
#include <PulseSensorPlayground.h> // Includes the PulseSensorPlayground Library.
Timer t;
PulseSensorPlayground pulseSensor;
char msg = "GET /update?key=**********";
SoftwareSerial esp8266(10,11);
//Variables
const int PulseWire = A0; // PulseSensor PURPLE WIRE connected to ANALOG PIN 0
const int LED13 = 13; // The on-board Arduino LED, close to PIN 13.
int Threshold = 550; //for heart rate sensor
float myTemp;
int myBPM;
char BPM;
char temp;
int error;
int panic;
int raw_myTemp;
float Voltage;
float tempC;
esp8266.begin(115200);
pulseSensor.analogInput(PulseWire);
pulseSensor.blinkOnPulse(LED13); //auto-magically blink Arduino's LED with heartbeat.
pulseSensor.setThreshold(Threshold);
// Double-check the "pulseSensor" object was created and "began" seeing a signal.
if (pulseSensor.begin()) {
Serial.println("We created a pulseSensor Object !"); //This prints one time at Arduino power-up, or on Arduino reset.
Serial.println("AT");
esp8266.println("AT");
delay(3000);
if(esp8266.find("OK"))
connectWiFi();
t.every(10000, getReadings);
t.every(10000, updateInfo);
panic_button();
start: //label
error=0;
t.update();
//Resend if transmission is not completed
if (error==1)
goto start; //go to label "start"
delay(4000);
void updateInfo()
char cmd = "AT+CIPSTART=\"TCP\",\"";
cmd += IP;
cmd += "\",80";
Serial.println(cmd);
esp8266.println(cmd);
delay(2000);
if(esp8266.find("Error"))
return;
cmd = msg ;
cmd += "&field1="; //field 1 for BPM
cmd += BPM;
cmd += "&field2="; //field 2 for temperature
cmd += temp;
cmd += "\r\n";
Serial.print("AT+CIPSEND=");
esp8266.print("AT+CIPSEND=");
Serial.println(cmd.length());
esp8266.println(cmd.length());
Serial.print(cmd);
esp8266.print(cmd);
Serial.println("AT+CIPCLOSE");
esp8266.println("AT+CIPCLOSE");
//Resend...
error=1;
boolean connectWiFi()
Serial.println("AT+CWMODE=1");
esp8266.println("AT+CWMODE=1");
delay(2000);
char cmd="AT+CWJAP=\"";
cmd+=SSID;
cmd+="\",\"";
cmd+=PASS;
cmd+="\"";
delay(5000);
return true;
return false;
void getReadings(){
raw_myTemp = analogRead(A1);
Voltage = (raw_myTemp / 1023.0) * 5000; // 5000 to get millivots.
tempC = Voltage * 0.1;
myTemp = (tempC * 1.8) + 32; // conver to F
Serial.println(myTemp);
int myBPM = pulseSensor.getBeatsPerMinute(); // Calls function on our pulseSensor object that returns BPM as an "int".
// "myBPM" hold this BPM value now.
if (pulseSensor.sawStartOfBeat()) { // Constantly test to see if "a beat happened".
Serial.println(myBPM); // Print the value inside of myBPM.
delay(20);
char buffer1[10];
char buffer2[10];
BPM = dtostrf(myBPM, 4, 1, buffer1);
temp = dtostrf(myTemp, 4, 1, buffer2);
void panic_button(){
panic = digitalRead(8);
if(panic == HIGH){
Serial.println(panic);
cmd += IP;
cmd += "\",80";
delay(2000);
return;
cmd = msg ;
cmd += "&field3=";
cmd += panic;
cmd += "\r\n";
Serial.print(cmd);
esp8266.print(cmd);
//Resend...
error=1;
