IoT carrier cloud messenger widget
What code can I use to clear the contents of the messenger widget on my projects?
messengerwidget.clear();
Thanks
Can you please explain a bit more detailed? I have some problem.
I have a messenger widget on my dashboard and it is connected to a variable called 'secret code'.
So how will messengerwidget.clear(); work?
How does it know which messenger to clear? Where do I define messenger widget?
(I just added that line to my code and it failed to compile.) Any help appreciated :slight_smile:
So you have some random code, that uses a random protocol and you want to do something random? The above answer is the best you will get.
HINT : You are asking in the programming section
For some reason this topic is attracting attention. The original question is too vague and lacks any useful detail so cannot sensibly be answered. If you want to ask a similar question please read the forum instructions first: How to get the best out of this forum
Asking vague questions with no information just wastes everyone's time.
