IoT Cloud - IoT33 Offline and Rebooting
I signed up to the Maker 25 Things Package, connected my IoT 33, configured it on the IoT Cloud, added a Thing, Configured Network and a Varible uploaded the sketch.
The IoT 33 just cycles and cycles and never connects to the Cloud.
I can ping it while it is up.
The IoT 33 works perfectly with non cloud as a web server, and it has firmware 1.4.8 (Wifinana)
This is from the Serial Monitor
***** Arduino IoT Cloud - configuration info *****
Device ID: e725417e-9ad3-49c3-8781-b4f5d23a9ca9
MQTT Broker: mqtts-sa.iot.arduino.cc:8883
WiFi.status(): 0
Current WiFi Firmware: 1.4.8
Connected to "Home Wifi 3G"
WiFi.status(): 0
WiFi.status(): 0
WiFi.status(): 0
If anyone can help would be appreciated
Take a look at https://support.arduino.cc/hc/en-us/articles/360019355679-If-your-device-can-t-be-added-or-won-t-connect-to-IoT-Cloud. If the issue persist, contact Arduino Tech Support via Contact us.
@jrgoodwin i suspect the board is taking a bit too much to connect to the WiFi network and then the watchdog resets the board. Would you try to run ArduinoCloud with watchdog disabled ?
To do this you need to change this line in your setup function
ArduinoCloud.begin(ArduinoIoTPreferredConnection);
to this
ArduinoCloud.begin(ArduinoIoTPreferredConnection, false);
