IoT Cloud Issue with variables types - Illuminance always zero
How to set up illuminance to display at Dashboard?
I set up my project weather station...see code below
unfortunately, I got an error regarding variables...
so here is my Illuminance which is a bit disappointing we can not see what type it is: string, int or float?
when I try to build it... I have error
Start verifying
/tmp/079528558/comfort_Station_Office_apr18a/comfort_Station_Office_apr18a.ino: In function 'void loop()':
/tmp/079528558/comfort_Station_Office_apr18a/comfort_Station_Office_apr18a.ino:43:56: error: cannot bind non-const lvalue reference of type 'int&' to an rvalue of type 'int'
carrier.Light.readColor(none, none, none, illuminance);
it works when I set up illuminance as Int
but then my values are not display on cloud
strangely it works on local hub
Any help will be appreciated :slight_smile:
#include "thingProperties.h"
#include <Arduino_MKRIoTCarrier.h>
MKRIoTCarrier carrier;
  // Initialize serial and wait for port to open:
  while (!Serial);
  // Defined in thingProperties.h
  initProperties();
  // Connect to Arduino IoT Cloud
  ArduinoCloud.begin(ArduinoIoTPreferredConnection);
  //Get Cloud Info/errors , 0 (only errors) up to 4
  setDebugMessageLevel(2);
  ArduinoCloud.printDebugInfo();
  //Wait to get cloud connection to init the carrier
  while (ArduinoCloud.connected() != 1) {
    ArduinoCloud.update();
  CARRIER_CASE = true;
  carrier.begin();
  carrier.display.setRotation(0);
  delay(1500);
  carrier.Buttons.update();
  while (!carrier.Light.colorAvailable()) {
    delay(5);
  int none;
  temperature = carrier.Env.readTemperature();
  humidity = carrier.Env.readHumidity();
  pressure = carrier.Pressure.readPressure();
  if (carrier.Button0.onTouchDown()) {
    //configuring display, setting background color, text size and text color
    carrier.display.fillScreen(ST77XX_RED); //red background
    carrier.display.setTextColor(ST77XX_WHITE); //white text
    carrier.display.setTextSize(2); //medium sized text
    carrier.display.setCursor(30, 110); //sets position for printing (x and y)
    carrier.display.print("Temp: ");
    carrier.display.print(temperature);
    carrier.display.println(" C");
  if (carrier.Button1.onTouchDown()) {
    carrier.display.fillScreen(ST77XX_BLUE); //red background
    carrier.display.setCursor(30, 110); //sets new position for printing (x and y)
    carrier.display.print("Humi: ");
    carrier.display.print(humidity);
    carrier.display.println(" %");
  if (carrier.Button2.onTouchDown()) {
    carrier.display.fillScreen(ST77XX_YELLOW);
    carrier.display.setTextColor(ST77XX_RED);
    carrier.display.print("Illuminance: ");
    carrier.display.print(illuminance);
    carrier.display.println(" lux");
  if (carrier.Button3.onTouchDown()) {
    carrier.display.fillScreen(ST77XX_WHITE);
    carrier.display.print("Pressure: "); //kPa
    carrier.display.print(pressure);
    carrier.display.println(" kPa");
  if (carrier.Button4.onTouchDown()) {
    if (humidity >= 60 && temperature >= 15  && temperature < 20) {
      weather_report = "It is very humid ";
    } else if (temperature >= 20 && humidity < 60) {
      weather_report = "Warm and comfortable";
    } else if (temperature <= 16 ) {
      weather_report = "A little cold";
    else {
      weather_report = "Weather is normal";
  //delay(3000);
  //carrier.Buttons.update();
I spent quite a lots of time and can not solve this and get it working...
anyone manage to get Lux Level via IoT working?
Does anyone manage to get it working? I still can not fix it..
I still have to set
int = illuminance;
anyone knows what type is CloudIlluminance ? and why I have to set it it int?
CloudIlluminance illuminance;
it is so frustrating not being able to find such a basic information...
CloudIlluminance illuminance; is float type and not an integer
so code needs to be modified to:
  int illuminanceInt;
  carrier.Light.readColor(none, none, none, illuminanceInt);
  Serial.println(illuminanceInt);
  illuminance = illuminanceInt;
and then other code remain:
carrier.display.println(illuminance, 0);
