I recently migrated from Cayenne to IOT Cloud and have a strange problem.
I have a simple sketch where I can turn on/off a relay with a button. But when it is on, it will be turned off during night by the IOT Platform. This sketch runs at my brother’s summerhouse, so to check this, I set up the same sketch on my desktop.
When it’s turned on it will be turned off. When its off nothing happens.
I’ve run this sketch for 6 years on Cayenne without any problems. Is there anything with IOT Cloud I need to be aware of?
Are these the same relays that you used with Cayenne? If not, I recommend testing the relays separately. Please check if those are active high or active low.
If you are looking forward to doing some more mind-blowing projects with IoT cloud, you can check this out:
