I have code for a temperature logger that I've created using the Arduino IDE software that works well. I now want to add this code to the IoT arduino cloud so that the Ardunio R4 Wifi sends the temperature data to the cloud. The IoT cloud has created me the start of a sketch that includes the basic code I need to float the temperature data I'm trying to collect but when I try and merge it with my existing code I encounter problems. Can anyone fix this for me?
my existing code that works
#include <OneWire.h>
#include <DallasTemperature.h>
#include <SD.h>
const int SENSOR_PIN = 13; // Arduino pin connected to DS18B20 sensor's DQ pin
OneWire oneWire(SENSOR_PIN); // setup a oneWire instance
DallasTemperature tempSensor(&oneWire); // pass oneWire to DallasTemperature library
LiquidCrystal_I2C lcd(0x3F, 16, 2); // I2C address 0x3F (from DIYables LCD), 16 column and 2 rows
float tempCelsius; // temperature in Celsius
float tempFahrenheit; // temperature in Fahrenheit
Serial.begin(9600); // initialize serial
tempSensor.begin(); // initialize the sensor
lcd.init(); // initialize the lcd
lcd.backlight(); // open the backlight
tempSensor.requestTemperatures(); // send the command to get temperatures
tempCelsius = tempSensor.getTempCByIndex(0); // read temperature in Celsius
Serial.print(tempCelsius); // print the temperature in Celsius
Serial.println("°C");
lcd.clear();
lcd.setCursor(0, 0); // start to print at the first row
lcd.print("CONCRETE TEMP:"); // print concrete temp wording
lcd.setCursor(0, 1); // start to print at the second row
lcd.print(tempCelsius); // print the temperature in Celsius
lcd.print((char)223); // print ° character
lcd.print("C");
delay(1000); // read temperature once every 15 minutes which is 900000 ms
IoT generated sketch
Sketch generated by the Arduino IoT Cloud Thing "Untitled"
https://create.arduino.cc/cloud/things/fd1441dc-f3f9-4a6d-8c75-a3277dceaedc
Arduino IoT Cloud Variables description
The following variables are automatically generated and updated when changes are made to the Thing
float Concrete_Temperature;
Variables which are marked as READ/WRITE in the Cloud Thing will also have functions
which are called when their values are changed from the Dashboard.
These functions are generated with the Thing and added at the end of this sketch.
#include "thingProperties.h"
// Initialize serial and wait for port to open:
// This delay gives the chance to wait for a Serial Monitor without blocking if none is found
delay(1500);
// Defined in thingProperties.h
initProperties();
// Connect to Arduino IoT Cloud
ArduinoCloud.begin(ArduinoIoTPreferredConnection);
The following function allows you to obtain more information
related to the state of network and IoT Cloud connection and errors
the higher number the more granular information you’ll get.
The default is 0 (only errors).
Maximum is 4
setDebugMessageLevel(2);
ArduinoCloud.printDebugInfo();
ArduinoCloud.update();
// Your code here
I've used ChatGPT to fix my code and make it work with the Arduino IoT cloud. I can see that the Arduino R4 board is sending data over the wifi and is updating the cloud every 5 seconds as expected, but the floating point variable isn't updating. The last value that is always being returned is '0'. I know that this must be an issue with software/code as opposed to hardware as when I open the serial manager I can see the temperature values are reading correctly and also my LCD screen is outputting an accurate temperature.
Below is my code. How do I fix the issue of the last updated value not returning the correct floating point value? Do Arduino Team have a customer service helpline or chat function? I think this might be an easy fix for someone who's more experienced than me.
#include <SD.h>
#include "thingProperties.h" // Include Arduino IoT Cloud Thing properties
#include <Arduino_ConnectionHandler.h>
float tempCelsius; // temperature in Celsius (floating-point)
// Connect to WiFi
Serial.println("Attempting to connect to WiFi...");
while (!WiFi.begin(SECRET_SSID, SECRET_OPTIONAL_PASS)) {
Serial.println("Failed to connect to WiFi. Retrying...");
// Wait for WiFi connection to be established
Serial.println("Connecting to WiFi...");
Serial.println("Connected to WiFi!");
// Initialize Arduino IoT Cloud
Maximum is 4
initProperties();
float tempCelsius = tempSensor.getTempCByIndex(0); // read temperature in Celsius
lcd.clear();
lcd.print("C");
ArduinoCloud.update(); // Update Arduino IoT Cloud
// Function called when Concrete_Temperature property changes
void on_Concrete_Temperature_change() {
// You can add custom behavior here if needed
