IoT Create Agent Error
Hello everyone. I Am trying to do my first led switch IoT project. I am following a YT video. I am stuck at adding my ESP32 to in Add Device. WHen I try I can see flashing fast a popup that says Create Agent not found. I did install it many time. I run it in admin mode. During the install I am NOT getting prompt for ceritifcates. I tried Chrome Firefox and Edge. I have Silicon Labs CP210x USB to UART Bridge on COM6. I have no problem uploading code to ESP32 with Arduino IDE. Please see attached log. The console report invalid signature: hash tag doesn't match. I am on Windows 11 22H2 . Thank you for the help.
Update. itt seems that ESP32 has to be added via third party device. I found in the documentation that Arduino Uno IoT 33 is more suitable for IoT. I will buy one today unless someone has a better suggestion. Thank you.
create agent console log.txt (146.1 KB)
Hello. Did I post that in the wrong thread?
@jimmy747 which is the issue now? you wrote this so i thought your issue was solved.
Thank you pennam. I got IoT working with Ubidots. I am off today so I will test again but today I will test with the 8266 I just received
It seems more straight forward. I will report here.
