IoT display problem
Hi Guys:
I'm having some problems with my IoT cloud editor... I'm going to address the problems in seperate posts. First of all I'm having a graphics problem. When I try and display "boards" when I'm in the editor the boards screen is "underneath" the main screen and almost impossible to read.
I'm using a normal computer and monitor. Dell Optiplex 9020 with an acer 20 inch monitor. Using Windows 11.
What's causing this problem and how can I fix it. It's unreadable.
I also have this too.
win10.
I'm using Windows 11... It's very annoying! Hopefully someone will have a cure! Thanks for letting me know I'm not alone.
Hi @Dr_Bundolo and @hammy,
can you please provide some details about your setup?
I read you're on Win11 and Win10.
Which browser are you using? Microsoft Edge, Google Chrome, Firefox, or something else?
Which version?
Thank you for any further details you can provide.
Firefox for me .
The same here:
Thanks for taking the time to answer. The problem is the same with the web editor... The transparency problem also exists with other menus.
I am using WIndows 11 and the current version of Google Chrome. Using a Dell Optiplex 9020 SFF with an acer LED monitor set at 1600 x 1200.
Hi, I'm sorry, I can't reproduce this issue on my Dell laptop with Windows 10 and with Chrome.
I noticed an error in the console in the last screenshot from @FernandoGarcia .
Can you please try to switch the theme from light to dark or viceversa, and see if something changes?
You can find the theme switcher in the left panel (see screenshot):
Hi!
Changing the theme solves the problem but still there tons of errors on console.
Best regards.
Good to know it's solved for you @FernandoGarcia .
@Dr_Bundolo can you please check if this works for you too?
Yes, changing the display to dark solved the problem.
