IoT with ESP8226: Real-time communication
I’d like guidance on an IoT issue with ESP8266 in the communication part. My ESP has been programmed with Arduino, has a Webserver running on it, It has Static IP, it’s connected to a router in my house, in my house also has a Static IP on the internet. I’ve created a mobile app wich access the Static IP of my house and sends a command that should reach the ESP8266 device. The goal is to make the communication in real time, where by pressing a button in the app, will immediately trigger “something” in the ESP.
My question is:
How does the command sent from my cell phone find the ESP8266 device connected to the router?
IMPORTANT: I don’t wanna have to change anything on my router, that is, I don’t want to access my router settings to redirect requests to the IP of the ESP8266.
Yes. Port forwarding on your router is complex and introduces a security risk. Look at the architecture of Blynk as an example to get round this. You can do something similar if you use a network service which includes a Apache/php/MySQL or an equivalent. In principle, your cell phone application posts a transaction via an external web server and your iot application polls the web server constantly (as an http client) to find these transactions.
I didn't want to quote Blynk, but that's exactly what I imagined. However, if I create an HTTP Client and do Polling on a server (as I suppose Blynk does...), I'm imagining there will be a huge number of requests to the server in a short time. Also, I'm imagining that when there are many IoT devices running, my internal network (provided by my router) will also be overloaded with the requests. Isn't it? Thanks!
Hello
I am trying to do something similar. Is there any examples that I can look at.
I just like to be able to send and receive data from a website to the ESP8266 module. The module I bought is called HUZZAH made by adafruit. I am using Ardunio environment to program it.
I then will send data back and forth between the WiFi module and a MEGA2560 via the RX0/TX0 port.
I think doing it from a website would be easier than creating an APP. Since the website can be access with a phone, computers, etc.
I appreciate any help. Thanks Bobby
