IP address of Ethernet shield
I am totally new to Arduino and, of course, new to the Ethernet Shield. I decided to try and run the Web Server tutorial code http://arduino.cc/en/Tutorial/WebServer .
Obviously the code needs to be changed to reflect the MAC address of the shield and the IP of the shield. I expected to be able to simply plug in the shield (attached to the Mega) to my router and then log into the router to check out the “attached devices” page to find the IP and MAC addresses. I can see my computer, cell phone and Tablet but not the Shield. Activity lights appear to indicate the Shield is properly attached but it does not show on the attached devices list.
What am I doing wrong?
Thanks.
Scimajor:
Thanks.
There should be no need to change the mac address, unless there is a clash
You MUST change the ip address to match your network:
change this line:
IPAddress ip(192,168,1, 177);
So that the first 3 numbers match your network and subnet…
so if a device on your network is on 192.168.0.xx
Change above line to :
IPAddress ip(192,168,0, 177);
if your device is on network 192.168.5.xx change the line to:
IPAddress ip(192,168,5, 177);
The reason you cannot see the device is because, whilst it may be connected, it is not ‘within’ the domain your router is looking at.
If you get stuck, then post the addresses your computer/tablet show up at.
Thanks for the information on the MAC address.
When I poll "attached devices" on my router page (192.168.1.1 ) with the Ethernet shield attached I see the following:
192.168.1.6 Epson (my wireless network printer) 192.168.1.110 My-PC (my computer hard wired) 192.168.3 Android_followed by numbers (my wireless ... obviously ...tablet) 192.168.1.253 unknown (my phone)
Notice there is not an IP for the shield. How can I find an IP when it does not seem to exist?
Simple combined client (use serial monitor to test) and server (use browser to test) you can try.
//zoomkat 12-08-11, combined client and server
//simple button GET with iframe code
//for use with IDE 1.0
//open serial monitor and send an g to test client and
//see what the arduino client/server receives
//web page buttons make pin 4 high/low
//use the \ slash to escape the " in the html
//address will look like http://192.168.1.102:84 when submited
//for use with W5100 based ethernet shields
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
IPAddress ip(192,168,1,102); // ip in lan
IPAddress gateway(192,168,1,1); // internet access via router
IPAddress subnet(255,255,255,0); //subnet mask
IPAddress myserver(208,104,2,86); // zoomkat web page
EthernetServer server(84); //server port
EthernetClient client;
String readString;
void setup(){
  pinMode(4, OUTPUT); //pin selected to control
  Ethernet.begin(mac, ip, subnet, gateway);
  server.begin();
  Serial.println("server/client 1.0 test 12/08/11"); // keep track of what is loaded
  Serial.println("Send an g in serial monitor to test client"); // what to do to test client
void loop(){
  // check for serial input
  if (Serial.available() > 0)
    byte inChar;
    inChar = Serial.read();
    if(inChar == 'g')
      sendGET(); // call sendGET function
  if (client) {
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        //read char by char HTTP request
        if (readString.length() < 100) {
          //store characters to string
          readString += c;
          //Serial.print(c);
        //if HTTP request has ended
        if (c == '\n') {
          Serial.println(readString); //print to serial monitor for debuging
            //now output HTML data header
          if(readString.indexOf('?') >=0) { //don't send new page
            client.println("HTTP/1.1 204 Zoomkat");
            client.println();
            client.println();
          else {
            client.println("HTTP/1.1 200 OK"); //send new page
            client.println("Content-Type: text/html");
            client.println();
            client.println("<HTML>");
            client.println("<HEAD>");
            client.println("<TITLE>Arduino GET test page</TITLE>");
            client.println("</HEAD>");
            client.println("<BODY>");
            client.println("<H1>Zoomkat's simple Arduino 1.0 button</H1>");
            client.println("<a href=\"/?on\" target=\"inlineframe\">ON</a>");
            client.println("<a href=\"/?off\" target=\"inlineframe\">OFF</a>");
            //client.println("<IFRAME name=inlineframe src=\"res://D:/WINDOWS/dnserror.htm\" width=1 height=1\">");
            client.println("<IFRAME name=inlineframe style=\"display:none\" >");
            client.println("</IFRAME>");
            client.println("</BODY>");
            client.println("</HTML>");
          delay(1);
          //stopping client
          client.stop();
          ///////////////////// control arduino pin
          if(readString.indexOf("on") >0)//checks for on
            digitalWrite(4, HIGH);    // set pin 4 high
            Serial.println("Led On");
          if(readString.indexOf("off") >0)//checks for off
            digitalWrite(4, LOW);    // set pin 4 low
            Serial.println("Led Off");
          //clearing string for next read
          readString="";
void sendGET() //client function to send/receie GET request data.
  if (client.connect(myserver, 80)) {
    Serial.println("connected");
    client.println("GET /~shb/arduino.txt HTTP/1.0");
    client.println();
  else {
    Serial.println("connection failed");
  while(client.connected() && !client.available()) delay(1); //waits for data
  while (client.connected() || client.available()) { //connected or data available
    Serial.print(c);
  Serial.println("disconnecting.");
  Serial.println("==================");
  client.stop();
Apparently I'm missing something very basic. Where are you getting 192.168.1.102 from? I assuming that's the IP of the Ethernet where are you getting 102?
Is it perhaps that the IP isn't assigned by the router until the code is running on the Ethernet shield? Is that what I am missing?
WHat type or router do you have? Maybe it does only the DHCP addresses ?
Have you tried an IP scanner - http://www.radmin.com/products/ipscanner/ - ?
and - http://www.radmin.com/products/previousversions/portscanner.php - ?
No, havn't tried any 3rd party IP scanners. I figured if I log into the router and I can't see the device then 3rd party software has no chance of finding it either.
It's a netgear router. I am not home or I would post the model number. It dynamically assignes an IP to any device attached to it(wireless or hardwired). It is possible, however, to make it choose a particular IP but only given the device name.
The dhcp address range is in the LAN settings on the Netgear routers. You can use a static ip assignment outside that range, or use the dhcp client on the shield to get an ip. Don't use any static ip address inside the dhcp range.
For dhcp assigned network settings:
if(Ethernet.begin(mac) == 0)
   Serial.println("No dhcp");
Scimajor: Apparently I'm missing something very basic. Where are you getting 192.168.1.102 from? I assuming that's the IP of the Ethernet where are you getting 102?
It is very basic. My router is using 192.168.1.1, my laptop is using 192.168.1.3, and another pc is using 192.168.1.101, so for the number in the arduino ip address I can use most any number between 0 and 255 except those in use. I just simply used 102 as it is easy to remember. You can use a number 0-255 as long as another device is not already using it.
