I'm trying to make a program where I enter data into an html form on a host server but I don't know what IP address to put in the form:
Obviously not the local ip. Where can I get this IP?you may follow this tutorial:
ESP8266 NodeMCU Publish Sensor Readings to ThingSpeak (easiest way)
I followed this tutorial:
https://randomnerdtutorials.com/visualize-esp32-esp8266-sensor-readings-from-anywhere/
By the way, his are the best I've ever read!! The point is that I want to complement this tutorial to send, from html, information to esp. My previous post lacked information. Didn't realize it was missing...
<h2>Register New Temperature:</h2>
<form action='ESP_IP' method='POST'>
<label for='temperature'>Temperature (°C):</label>
<input type='number' step='0.1' id='temperature' name='temperature' required><br><br>
<label for='time'>Time (seconds):</label>
<input type='number' id='time' name='time' required><br><br>
<input type='submit' value='Register'>
</form>
The idea is to send to esp temperatures and times to control relays. I've tried a lot. I read a lot. I saw many examples. But I still haven't figured out how to do that. I managed more or less to run esp as a web server but I've already noticed that the exchange of information between esp and html is complicated. There are constant crashes and a lot of delay in exchanging information. Also, for my project it's better to control on a web server.
The internal IP is:
192.xxx.xx.107
On the router I saw IP Lan:
192.xxx.xx.1
Why is ESP8266 not receiving this data?
<form action='/' method='POST'>
</form>
The sketch:
void handleAddTemperature() {
float temperature = server.arg("temperature").toFloat();
unsigned long time = server.arg("time").toInt();
Serial.print("Received temperature: ");
Serial.println(temperature);
Serial.print("Received time: ");
Serial.println(time);
if (numTemperatures < MAX_TEMPERATURES) {
temperatureData[numTemperatures].temperature = temperature;
temperatureData[numTemperatures].time = time;
numTemperatures++;
saveTemperatureData();
server.send(200, "text/html", "<script>window.location.href = '/';</script>");
The entire sketch
#include <ESP8266WiFi.h>
#include <ESP8266WebServer.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#include <FS.h>
#include "secrets.h"
const char* ssid = STASSID;
const char* pass = STAPSK;
// Sensor de temperatura conectado na GPIO 4 / D2
#define ONE_WIRE_BUS 4
// Pinos do relê
#define HEATER_RELAY_PIN 5
#define COOLER_RELAY_PIN 4
// Hysteresis da temperatura
#define HYSTERESIS 0.4
// Web server
ESP8266WebServer server(80);
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
// Temperaturas e tempos
struct TemperatureData {
float temperature;
unsigned long time;
const int MAX_TEMPERATURES = 15; // Limite de 15 passos
TemperatureData temperatureData[MAX_TEMPERATURES];
int numTemperatures = 0;
int currentTemperatureIndex = 0;
bool fermentationStarted = false;
unsigned long targetTime;
unsigned long remainingTime;
unsigned long elapsedTime;
unsigned long tempoFase;
unsigned long tempoAtual;
bool atualizaTarget = false;
bool contagemTempo = false;
// Função auxiliar para converter float em string com determinada precisão
String floatToString(float value, int precision) {
char buffer[20];
sprintf(buffer, "%.*f", precision, value);
return String(buffer);
// Carregar dados de temperatura do arquivo
void loadTemperatureData() {
if (SPIFFS.begin()) {
if (SPIFFS.exists("/temperatures.txt")) {
File file = SPIFFS.open("/temperatures.txt", "r");
if (file) {
while (file.available() && numTemperatures < MAX_TEMPERATURES) {
String line = file.readStringUntil('\n');
int separatorIndex = line.indexOf(',');
if (separatorIndex != -1) {
temperatureData[numTemperatures].temperature = line.substring(0, separatorIndex).toFloat();
temperatureData[numTemperatures].time = line.substring(separatorIndex + 1).toInt();
numTemperatures++;
file.close();
SPIFFS.end();
// Salvar dados de temperatura em arquivo
void saveTemperatureData() {
File file = SPIFFS.open("/temperatures.txt", "w");
if (file) {
for (int i = 0; i < numTemperatures; i++) {
file.println(floatToString(temperatureData[i].temperature, 2) + "," + String(temperatureData[i].time));
file.close();
SPIFFS.end();
// Script da página html
void handleRootPage() {
String html;
File file = SPIFFS.open("/index.html", "r");
if (file) {
html = file.readString();
file.close();
SPIFFS.end();
String temperaturesHtml = "";
temperaturesHtml += "<li>";
temperaturesHtml += "Temperatura: " + floatToString(temperatureData[i].temperature, 2) + " °C, ";
temperaturesHtml += "Tempo: " + String(temperatureData[i].time) + " segundos";
temperaturesHtml += " [<a href='/delete?index=" + String(i) + "'>Deletar</a>]";
temperaturesHtml += "</li>";
html.replace("{{temperatures}}", temperaturesHtml);
server.send(200, "text/html", html);
// Script para adicionar nova temperatura/tempo
Serial.print("Temperatura recebida: ");
Serial.print("Tempo recebido: ");
numTemperatures++;
// Script para deletar temperature/tempo
void handleDeleteTemperature() {
int index = server.arg("index").toInt();
if (index >= 0 && index < numTemperatures) {
for (int i = index; i < numTemperatures - 1; i++) {
temperatureData[i] = temperatureData[i + 1];
numTemperatures--;
server.sendHeader("Location", "/");
server.send(303);
// Leitura da temperatura do sensor DS18B20
float readTemperature() {
sensors.requestTemperatures();
return sensors.getTempCByIndex(0);
// Initialização dos relays
void initializeRelays() {
pinMode(HEATER_RELAY_PIN, OUTPUT);
digitalWrite(HEATER_RELAY_PIN, LOW);
pinMode(COOLER_RELAY_PIN, OUTPUT);
digitalWrite(COOLER_RELAY_PIN, LOW);
// Controle dos relays basedo na temperatura corrente e temperatura alvo
void controlRelays(float currentTemperature, float targetTemperature) {
static unsigned long lastCoolerOffTime = 0;
bool heaterState = digitalRead(HEATER_RELAY_PIN);
bool coolerState = digitalRead(COOLER_RELAY_PIN);
if (currentTemperature < targetTemperature - HYSTERESIS) {
digitalWrite(HEATER_RELAY_PIN, HIGH);
heaterState = true;
Serial.println("Aquecedor ligado");
Serial.println("Temperatura alvo: ");
Serial.println(targetTemperature);
Serial.println("Tempo alvo: ");
Serial.println(targetTime);
} else if (currentTemperature > targetTemperature + HYSTERESIS) {
if (!coolerState && millis() - lastCoolerOffTime >= 5 * 60 * 1000) {
digitalWrite(COOLER_RELAY_PIN, HIGH);
Serial.println("Geladeira ligada");
coolerState = true;
if (targetTemperature - HYSTERESIS <= currentTemperature && currentTemperature <= targetTemperature + HYSTERESIS && coolerState) {
Serial.println("Geladeira desligada");
coolerState = false;
lastCoolerOffTime = millis();
if (targetTemperature - HYSTERESIS <= currentTemperature && currentTemperature <= targetTemperature + HYSTERESIS && heaterState) {
Serial.println("Aquecedor desligado");
heaterState = false;
// Verifica se o processo de fermentatação está completo
bool isFermentationComplete() {
return currentTemperatureIndex == numTemperatures;
// Recebe o comando para iniciar a fermentação alterando para true, que vai ser lido no loop
void handleStartTemperatureControl() {
fermentationStarted = true;
server.send(200, "text/plain", "Fermentação Iniciada");
// Envia para html indicação de fermentação completa
void handleFermentationComplete() {
String html = "<html><head><title>Fermentação Concluída</title></head><body>";
html += "<h1>Fermentação Concluída!</h1>";
html += "<p>A fermentação atingiu todas as temperaturas alvo.</p>";
html += "</body></html>";
// Script de envio de dados de temperatura/tempo para o html
void handleTemperatureData() {
float currentTemperature = readTemperature();
float targetTemperature = temperatureData[currentTemperatureIndex].temperature;
targetTime = temperatureData[currentTemperatureIndex].time;
elapsedTime = millis() / 1000 - temperatureData[currentTemperatureIndex].time;
// remainingTime = (temperatureData[currentTemperatureIndex].time > elapsedTime) ? temperatureData[currentTemperatureIndex].time - elapsedTime : 0;
// Create JSON response
String jsonResponse = "{";
jsonResponse += "\"currentTemperature\": " + floatToString(currentTemperature, 2) + ",";
jsonResponse += "\"targetTemperature\": " + floatToString(targetTemperature, 2) + ",";
jsonResponse += "\"remainingTime\": " + String(remainingTime) + ",";
jsonResponse += "\"targetTime\": " + String(targetTime);
jsonResponse += "}";
server.send(200, "application/json", jsonResponse);
// Connecta ao Wi-Fi
WiFi.begin(ssid, pass);
Serial.println("Connecting to WiFi...");
Serial.println("Connected to WiFi");
// Inicia o servidor web
server.on("/", handleRootPage);
server.on("/add", handleAddTemperature);
server.on("/delete", handleDeleteTemperature);
server.on("/HTTP_POST, temperature", handleTemperatureData);
server.on("/start", handleStartTemperatureControl);
server.begin();
// Inicializa o sensor de temperatura
sensors.begin();
// Lê o arquivo de temperatura/tempo
loadTemperatureData();
// Inicializa os relays
initializeRelays();
// Seta o currentTemperatureIndex para 0 inicialmente
server.handleClient();
// Lê a temperatura atual
// Controla o início e término da fermentação
if (isFermentationComplete()) {
handleFermentationComplete();
} else if (fermentationStarted && currentTemperatureIndex < numTemperatures) {
controlRelays(currentTemperature, targetTemperature);
if (currentTemperature >= targetTemperature - HYSTERESIS && currentTemperature <= targetTemperature + HYSTERESIS) {
Serial.println("Temperatura alvo atingida! Início da contagem do tempo!");
atualizaTarget = true;
if (atualizaTarget == true){
tempoAtual = millis() / 1000;
Serial.println("Tempo atual: ");
Serial.println(tempoAtual);
tempoFase = tempoAtual + targetTime;
contagemTempo = true;
if (tempoFase > millis()/1000) {
unsigned long elapsed = ((millis()/1000) - tempoAtual);
unsigned long elapsedTime = (targetTime - elapsed);
Serial.println("Tempo que passou: ");
Serial.println(elapsed);
Serial.println("Tempo restante: ");
Serial.println(elapsedTime);
Serial.println(contagemTempo);
if (elapsedTime <= 1 && contagemTempo == true)
Serial.println("Tempo no alvo alcançado. Passando para a próxima etapa!");
currentTemperatureIndex++;
if (tempoFase < (millis()/1000) && contagemTempo == true) {
you are sending your data to your root document but on the server your
doesn't read any parameters (arg, args, hasArg,...)
Duplicate post here: IP esp8266 via webserverhere.
@mvrinaldi, please do not cross-post. Threads merged.
