Ipad Keyboard
Hello, is there any way to make bluetooth keyboard with arduino for ipad ? hm-10 or hc05 bluetooth ? or others ? if answer is yes, how can I make it ? do you have any ideas or link for it ? But not serial port emulation ? Ipad must see my arduino as keyboard ?
This module will do it for $20: https://www.adafruit.com/product/1535
If you only need 12 keys in your keyboard it doesn't even need an Arduino. :)
No I need all of keyboard keys :(
https://www.scan.co.uk/products/scanfx-bluetooth-keyboard-and-case-for-new-ipad-gen-1-3-and-4-coffee-macbook-look!?utm_source=google+shopping&utm_medium=cpc&gclid=CMS684qPi9ACFWIq0wodruMM0Q
If you wish to have an make a device talk to an Apple device you have to pay a lot of money to apple and a lawyer.
Another option is to take a $5 bluetooth keyboard like this one:
http://www.ebay.com/itm/Poetic-KeyBook-Bluetooth-Keyboard-Case-for-Apple-iPad-Air-5th-Gen-Black-/161822599058
And use analog multiplexers to replace the keyboard matrix. This would allow an Arduino to type any sequence on the iPad.
thanks, I think no way to send string to ipad with my arduino like a bluetooth keyboard emulation. Only can send by serial port emulation :(
johnwasser: This module will do it for $20: https://www.adafruit.com/product/1535
You can feed serial into that module at 9600 baud, so you may be able to feed it with a serial keyboard such as a ps2.
IF you can find a module that is.
edit
This may do the business though.
https://learn.adafruit.com/introducing-the-adafruit-bluefruit-le-uart-friend/downloads?view=all
Although i have not tried it as yet.
One other point i do not think earlier ipad supports BLE HID.
Something like this would allow data transfer. However if you want the arduino to send keys that operate as though you are pressink the touch screen keyboard i doubt it will work as the arduino has to appear to the ipad as a hid.
This https://www.adafruit.com/product/1535
Supports bluetooth 2.1 and should work.
Aleyna: thanks, I think no way to send string to ipad with my arduino like a bluetooth keyboard emulation. Only can send by serial port emulation :(
Here is a project to emulate a keyboard by changing the firmware on a $3 bluetooth module: http://www.instructables.com/id/3-Bluetooth-HID-Module-HC05-With-RN42-Firmware/ What makes you think that none of the proposed solutions will work?
johnwasser: Here is a project to emulate a keyboard by changing the firmware on a $3 bluetooth module: http://www.instructables.com/id/3-Bluetooth-HID-Module-HC05-With-RN42-Firmware/ What makes you think that none of the proposed solutions will work?
Quite .
I tried that solution though which basically rips off software for a cheap solution.
While i could get it to work with android , ipad refused to recognise it as an hid device.
Same with red bear stuff.
OP wants to talk to ipad witharduino via bluetooth as i do .
Would be delighted for someone to say you need this and this is how to do it.
Consider a IR keyboard: http://forum.arduino.cc/index.php?topic=317625.0
|446x500
I think this might be the problem: "Note: iOS requires that the remote Bluetooth device support an encrypted connection. When you establish a pairing record between your iOS device and a Bluetooth device, you are setting up encryption between the two devices." (from https://support.apple.com/en-us/HT204387)
Further reading indicates that maybe the MFI (Made For iPhone) chip is needed for the encryption and you have to license that chip from Apple. Looks like the best bet is to gut an existing iPad keyboard.
johnwasser:
As you suggested earlier, what i did in the end.
Wasted a lot of time though.
With the suppliers of those modules being out of stock every time i looked i do not think the OP and I are the only ones with the same requirements.
Gave my red bear stuff away to someone who later got it working but do not know how, although his ipad is a later version than mine.
I ordered one of those $5 bluetooth keyboard iPad cases. It will be interesting to see what is inside.
