ÍPAddress does not name a type
Using IDE 1.0. Set Mac and IP in the twitter example sketch but when I verify or upload sketch I get -"ÍPAddress does not name a type" - error plus a long list of errors beginning with - "In file included from". Hope this is clear Thanks
We’ve got to see your code and your error messages, not a lot of handwaving.
Take your pick. Its any of the example sketches for ethernet shield. Lot of use these forums are if thats the kind of reply you are going to get. Thanks for nothing. I'll figure it out myself.
stusmith6818: Take your pick. Its any of the example sketches for ethernet shield. Lot of use these forums are if thats the kind of reply you are going to get. Thanks for nothing. I'll figure it out myself.
Did somebody pee in your corn flakes? 8)
I’d suggest getting rid of the accent above the “I”.
This is the example code used, with my mac and ip info.
Twitter Client with Strings
This sketch connects to Twitter using an Ethernet shield. It parses the XML
returned, and looks for this is a tweet
You can use the Arduino Ethernet shield, or the Adafruit Ethernet shield,
either one will work, as long as it’s got a Wiznet Ethernet module on board.
This example uses the DHCP routines in the Ethernet library which is part of the
Arduino core from version 1.0 beta 1
This example uses the String library, which is part of the Arduino core from
version 0019.
Circuit:
  • Ethernet shield attached to pins 10, 11, 12, 13
created 21 May 2011
by Tom Igoe
This code is in the public domain.
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac = { 0x90, 0xA2, 0xDA, 0x0D, 0x01, 0xF5 };
IPAddress ip(192,168,1,20);
// initialize the library instance:
EthernetClient client;
const int requestInterval = 60000; // delay between requests
char serverName = “api.twitter.com”; // twitter URL
boolean requested; // whether you’ve made a request since connecting
long lastAttemptTime = 0; // last time you connected to the server, in milliseconds
String currentLine = “”; // string to hold the text from server
String tweet = “”; // string to hold the tweet
boolean readingTweet = false; // if you’re currently reading the tweet
// reserve space for the strings:
currentLine.reserve(256);
tweet.reserve(150);
// initialize serial:
// attempt a DHCP connection:
if (!Ethernet.begin(mac)) {
// if DHCP fails, start with a hard-coded address:
Ethernet.begin(mac, ip);
// connect to Twitter:
connectToServer();
if (client.connected()) {
if (client.available()) {
// read incoming bytes:
char inChar = client.read();
// add incoming byte to end of line:
currentLine += inChar;
// if you get a newline, clear the line:
if (inChar == ‘\n’) {
currentLine = “”;
// if the current line ends with , it will
// be followed by the tweet:
if ( currentLine.endsWith("")) {
// tweet is beginning. Clear the tweet string:
readingTweet = true;
tweet = “”;
// if you’re currently reading the bytes of a tweet,
// add them to the tweet String:
if (readingTweet) {
if (inChar != ‘<’) {
tweet += inChar;
else {
// if you got a “<” character,
// you’ve reached the end of the tweet:
Serial.println(tweet);
// close the connection to the server:
client.stop();
else if (millis() - lastAttemptTime > requestInterval) {
// if you’re not connected, and two minutes have passed since
// your last connection, then attempt to connect again:
connectToServer();
void connectToServer() {
// attempt to connect, and wait a millisecond:
Serial.println(“connecting to server…”);
if (client.connect(serverName, 80)) {
Serial.println(“making HTTP request…”);
// make HTTP GET request to twitter:
client.println(“GET /1/statuses/user_timeline.xml?screen_name=arduino&count=1 HTTP/1.1”);
client.println(“HOST: api.twitter.com”);
client.println();
// note the time of this connect attempt:
lastAttemptTime = millis();
These are the first few errors
In file included from /Users/stusmith6818/Documents/Arduino/libraries/Ethernet/Ethernet.h:5,
from TwitterClient.cpp:26:
/Users/stusmith6818/Documents/Arduino/libraries/Ethernet/Client.h:16: error: conflicting return type specified for ‘virtual void Client::write(uint8_t)’
/Applications/Arduino-2.app/Contents/Resources/Java/hardware/arduino/cores/arduino/Print.h:48: error: overriding ‘virtual size_t Print::write(uint8_t)’
And it highlights th IPAdress line in the sketch.
In file included from /Users/stusmith6818/Documents/Arduino/libraries/Ethernet/Ethernet.h:5, from TwitterClient.cpp:26: /Users/stusmith6818/Documents/Arduino/libraries/Ethernet/Client.h:16: error: conflicting return type specified for 'virtual void Client::write(uint8_t)' /Applications/Arduino-2.app/Contents/Resources/Java/hardware/arduino/cores/arduino/Print.h:48: error: overriding 'virtual size_t Print::write(uint8_t)' In file included from
The message, though, has absolutely nothing to do with the IPAddress line.
When I open the Twit example, and compile, I get this "error":
Binary sketch size: 15666 bytes (of a 30720 byte maximum)
So, somewhere, you have put a library in the Arduino library path that you should not have put there, and it is causing your problems. I suggest that you uninstall 1.0, and reinstall it.
What's with the -2 in Arduino-2.app? What version of the IDE are you really using?
That example is not the brightest example that Arduino team has foisted off onto unsuspecting users.
Yeah, right. That's a valid int. NOT!
thanks reinstalled and now uploads OK.
