IPAdress definition not found, inclusion error, how to solve it.
Hi all,
I have made a small ethernet server/client class that uses the ehternet lib from Arduino. But when i want to use it in my sketch by including it i get te following error:
C:\Users\Gebruiker\Documents\Arduino\libraries\CommunicationModuleTCPIP/CommunicationModuleTCPIP.h:38: error: 'IPAdress' has not been declared
The class and its base class looks the following:
Base class communicationmodule:
 * CommunicationModule.h
 *  Created on: 16 okt. 2013
 *      Author: Gebruiker
#ifndef COMMUNICATIONMODULE_H_
#define COMMUNICATIONMODULE_H_
#include "Arduino.h"
// ObjectInfo struct definition
struct ObjectInfo {
     int32_t ObjectXCor;
     int32_t ObjectYCor;
     int32_t ObjectMass;
struct SensorDataStruct{
     int32_t PingData;
     int32_t IRData;
     int32_t ForceData;
     int32_t CompassData;
union Packet{
     struct CommStruct{
     	ObjectInfo VisionData;
     	SensorDataStruct SensorData;
     } CommData;
     unsigned char bytes[28];
class CommunicationModule
   public:
	CommunicationModule();
    void Send();
    void Recieve();
    void SendBuffer();
	void RecieveBuffer();
	Packet SendData;
	Packet RecieveData;
   private:
     int _pin;
#endif /* COMMUNICATIONMODULE_H_ */
And the TCP class:
 * CommunicationModuleTCPIP.cpp
 * Author: Roy Stegers
 * This is the TCP/IP communication module class, it provides both the client and server functions.
 * A object can be a client or a server, never both at the same time.
#ifndef COMMUNICATIONMODULETCPIP_H_
#define COMMUNICATIONMODULETCPIP_H_
#include "CommunicationModule.h"
#include <SPI.h>
#include <Servo.h>
#include <Dhcp.h>
#include <Dns.h>
#include <Ethernet.h>
#include <EthernetClient.h>
#include <EthernetServer.h>
#include <EthernetUdp.h>
#include <util.h>
class CommunicationModuleTCPIP : public CommunicationModule
   public:
	CommunicationModuleTCPIP(byte MacAdress[], IPAddress ServerIPServerIPAdress, int ServPort, bool Server);
	CommunicationModuleTCPIP();
	int Connect(IPAdress ServerIP, int Port);
    void Send();
	void Send(Packet SendPacket);
    void Recieve();
	void SendBuffer(char Buffer[], int Size);
	void RecieveBuffer(char Buffer[], int Size);
	bool IsServer;
	byte Mac[];
	IPAddress ServerIP;
	int ServerPort;
	EthernetClient Client;
	EthernetServer ServerObject;
	bool DataRecieved;
   private:
#endif
The sketch that includes the TCP class:
#include <SPI.h>
#include <Servo.h>
#include <util.h>
#include <Dhcp.h>
#include <Dns.h>
#include <CommunicationModule.h>
#include <CommunicationModuleTCPIP.h>
void setup(){
void loop(){
Does anybody have a idea what the problem might be? All sugestions are welcome!
IPAddress, not IPAdress
(deleted)
Thank you! I saw the mis type. When i fixed it i got the followin error:
C:\Users\Gebruiker\Documents\Arduino\libraries\CommunicationModuleTCPIP\CommunicationModuleTCPIP.cpp: In constructor 'CommunicationModuleTCPIP::CommunicationModuleTCPIP()':
C:\Users\Gebruiker\Documents\Arduino\libraries\CommunicationModuleTCPIP\CommunicationModuleTCPIP.cpp:20: error: no matching function for call to 'EthernetServer::EthernetServer()'
C:\Program Files (x86)\Arduino\libraries\Ethernet/EthernetServer.h:14: note: candidates are: EthernetServer::EthernetServer(uint16_t)
C:\Program Files (x86)\Arduino\libraries\Ethernet/EthernetServer.h:9: note: EthernetServer::EthernetServer(const EthernetServer&)
Anybody know what the problem might be? I did in clude the ethernet lib both in my sketch and in the class files.
Well I found the problem, i needed to initiate the EthernetServer object in the default constructor. If fixed it by doing the following:
CommunicationModuleTCPIP::	CommunicationModuleTCPIP()
	:ServerObject(5000){
Thank you for your help.
