Ipod-controlled arduino-based mood lamp!
Hi. After tinkering with some code I finally managed to make this! ;D Here is the code.
// Ipod mood lamp
//By: Ryan Gosiaco
// Red led is MotorA=pin 9
// Green led is MotorB=pin 10
// Blue led is MotorC=pin 11
// I tweaked the code... so have fun!
#define PwmPinMotorA 9
#define PwmPinMotorB 10
#define PwmPinMotorC 11
#define DirectionPinMotorA 12
#define DirectionPinMotorB 13
#define DirectionPinMotorC 8
#define SerialSpeed 9600
#define BufferLength 16
#define LineEnd '#'
char inputBuffer[BufferLength];
  // motor pins must be outputs
  pinMode(PwmPinMotorA, OUTPUT);
  pinMode(PwmPinMotorB, OUTPUT);
  pinMode(PwmPinMotorC, OUTPUT);
  pinMode(DirectionPinMotorA, OUTPUT);
  pinMode(DirectionPinMotorB, OUTPUT);
  pinMode(DirectionPinMotorC, OUTPUT);
  Serial.begin(SerialSpeed);
// process a command string
void HandleCommand(char* input, int length)
  Serial.println(input);
  if (length < 2) { // not a valid command
    return;
  int value = 0;
  // calculate number following command
  if (length > 2) {
    value = atoi(&input[2]);
  int* command = (int*)input;
  // check commands
  // note that the two bytes are swapped, ie 'RA' means command AR
  switch(*command) {
    case 'FA':
      // motor A forwards
      analogWrite(PwmPinMotorA, value);
      digitalWrite(DirectionPinMotorA, HIGH);
    case 'RA':
      // motor A reverse
      digitalWrite(DirectionPinMotorA, LOW);
    case 'FB':
      // motor B forwards
      analogWrite(PwmPinMotorB, value);
      digitalWrite(DirectionPinMotorB, LOW);
    case 'RB':
      // motor B reverse
      digitalWrite(DirectionPinMotorB, HIGH);
      case 'FC':
      // motor C forwards
      analogWrite(PwmPinMotorC, value);
      digitalWrite(DirectionPinMotorC, LOW);
    case 'RC':
      // motor C reverse
      digitalWrite(DirectionPinMotorC, HIGH);
    default:
  // get a command string form the serial port
  int inputLength = 0;
  do {
    while (!Serial.available()); // wait for input
    inputBuffer[inputLength] = Serial.read(); // read it in
  } while (inputBuffer[inputLength] != LineEnd && ++inputLength < BufferLength);
  inputBuffer[inputLength] = 0; //  add null terminator
  HandleCommand(inputBuffer, inputLength);
Link to come!
Proccesing code
import oscP5.*;
import netP5.*;
import processing.serial.*;
Serial arduinoPort;
OscP5 oscP5;
float [] fader = new float [4];
  oscP5 = new OscP5(this,8000);
  arduinoPort = new Serial(this, Serial.list()[0], 9600);
void oscEvent(OscMessage theOscMessage) {
    String addr = theOscMessage.addrPattern();
       if(addr.indexOf("/1/fader") !=-1){
       String list[] = split(addr,'/');
     int  xfader = int(list[2].charAt(5) - 0x30);
     if(theOscMessage.get(0).floatValue() !=0){
     fader[xfader]  = theOscMessage.get(0).floatValue();
void draw() {
//---------------------------------Motor A
 if(fader[1] > 0.99){
    arduinoPort.write("AF255#");
  if(fader[1] > 0.89){
    arduinoPort.write("AF230#");
   if(fader[1] > 0.79){
    arduinoPort.write("AF205#");
   if(fader[1] > 0.69){
    arduinoPort.write("AF180#");
   if(fader[1] > 0.59){
    arduinoPort.write("AF155#");
   if(fader[1] > 0.49){
    arduinoPort.write("AF130#");
   if(fader[1] > 0.39){
    arduinoPort.write("AF105#");
   if(fader[1] > 0.29){
    arduinoPort.write("AF80#");
   if(fader[1] > 0.19){
    arduinoPort.write("AF55#");
   if(fader[1] > 0.14){
    arduinoPort.write("AF40#");
   if(fader[1] < 0.09){
    arduinoPort.write("AF30#");
  //--------------------------------Motor B
  if(fader[2] > 0.99){
    arduinoPort.write("BF255#");
  if(fader[2] > 0.89){
    arduinoPort.write("BF230#");
   if(fader[2] > 0.79){
    arduinoPort.write("BF205#");
   if(fader[2] > 0.69){
    arduinoPort.write("BF180#");
   if(fader[2] > 0.59){
    arduinoPort.write("BF155#");
   if(fader[2] > 0.49){
    arduinoPort.write("BF130#");
   if(fader[2] > 0.39){
    arduinoPort.write("BF105#");
   if(fader[2] > 0.29){
    arduinoPort.write("BF80#");
   if(fader[2] > 0.19){
    arduinoPort.write("BF55#");
    if(fader[2] > 0.14){
    arduinoPort.write("BF40#");
   if(fader[2] < 0.09){
    arduinoPort.write("BF30#");
  //--------------------------------Motor C
   if(fader[3] > 0.99){
    arduinoPort.write("CF255#");
  if(fader[3] > 0.89){
    arduinoPort.write("CF230#");
   if(fader[3] > 0.79){
    arduinoPort.write("CF205#");
   if(fader[3] > 0.69){
    arduinoPort.write("CF180#");
   if(fader[3] > 0.59){
    arduinoPort.write("CF155#");
   if(fader[3] > 0.49){
    arduinoPort.write("CF130#");
   if(fader[3] > 0.39){
    arduinoPort.write("CF105#");
   if(fader[3] > 0.29){
    arduinoPort.write("CF80#");
   if(fader[3] > 0.19){
    arduinoPort.write("CF55#");
    if(fader[3] > 0.14){
    arduinoPort.write("CF40#");
   if(fader[3] < 0.09){
    arduinoPort.write("CF30#");
  //----------------------------stop commands
     if(fader[1] < 0.99 && fader[1] > 0.09 ){
    arduinoPort.write("AF0#");
       if(fader[2] < 0.99 && fader[2] > 0.09 ){
    arduinoPort.write("BF0#");
       if(fader[3] < 0.99 && fader[3] > 0.09 ){
    arduinoPort.write("CF0#");
BTW I posted this in interfacing hardware already because I didn't know. :-/
LINK!!! http://camera.byethost4.com/arduino/ipodmoodlamp/
BTW The ipod app u need is touchosc
EDIT:- YouTube
any pictures or video available?
sounds cool
there is a pic in the link. I will post a video shortly. :wink:
Hi i'm using Arduino Diecimila board so I'm wondering if this code works for that plus my output is a LED connected in pin 9.
