I posted this over in Programming as well, but I'm starting to wonder if it's a hardware problem ( in which case I'm SOL because I know no hardware anything ever ).
The problem is this:
I'm trying to get an iPod to play/pause and restart tracks based on input from a Parallax Ping))) sensor. The sensor (as far as I know) works great, but I get no response from the iPod. I'm not getting any compiling errors, and I'm using a lot of borrowed (it works I think) code. I'm starting to think that something about the physical structure is causing the iPod not to respond. Here is a bit of code and then some images.
#include <iPodSerial.h>
#include <SimpleRemote.h>
SimpleRemote simpleRemote;
// initialize
int pingPin = 7 ; // Serial for Ping)))
int podPin = 0 ; // IPod TX, board RX
int podPout = 1 ; // IPod RX, board TX
int pingBaud = 9600 ; // Ping))) Baud rate
int podBaud = 19200 ; // IPod Baud rate
int threshOn = 20;
int threshOff = 40;
// set up
//iPodSerial();
//TODO: Why did I put this here?
simpleRemote.setup();
simpleRemote.loop();
simpleRemote.sendiPodOn();
delay(50);
simpleRemote.sendPlay();
simpleRemote.sendButtonReleased();
delay(5000);
Please help meeeeeee.
