IR Alarm System Code Not Working, Serial Outputs not matching sensor data
I am relatively new to Arduino, and this problem is a bit beyond me. I have a piece of modified open source code that was working before, but then stopped working properly. I have an IR sensor set to send a pulse to an analog pin when it detects motion, but the Serial Outputs are sending non=existent data. The TX light is also blinking in time with the Serial Outputs, but I assume this is normal.
Here is a link to the original program:
https://raw.githubusercontent.com/jedgarpark/Make_PIR_Sensor/master/MAKE_PIR_Sensor.pde
Here is my modified program:
int ledPin = 11;
int inputPin = A1;
int pirState = LOW;
int val = 0;
  pinMode(ledPin, OUTPUT);
  pinMode(inputPin, INPUT);
void loop(){
    if (pirState == LOW) {
      Serial.println("Motion detected!");
      pirState = HIGH;
   else {
      digitalWrite(ledPin, LOW); // turn LED OFF
      delay(300);
      if (pirState == HIGH){
      Serial.println("Motion ended!");
      pirState = LOW;
By:
do you mean to:
if (analogRead(pirState) == LOW) {
