Ir and keypad libraries
For some reason the libraries aren't being recognized has anyone had this problem
Nope. I'm always able to recognize a library. They have big signs out front that say LIBRARY.
Which libraries did you download? From where? Where did you install them?
I downloaded the keypad libraries right off this website. Installed it just like it says on here…
So for instance when you say
#include <LiquidCrystal.h>
The LiquidCrystal will turn orange
And it won’t on these libraries
So none of the code will work
For one thing the library is “Keypad”, not “keypad”. It highlights fine for me. Did you re-start the IDE after installing the library?
Did you mean “IRremote” when you said “ir”?
The color of the word is based on the “keywords.txt” file included with the library. The name “IRremote” is not highlighted because it is not in the keywords.txt file of the IRremote library. It will still work fine.
