IR Code is random when Led Ring enabled
Hello,
I have a IR Sensor that should turn on Led Ring when i click on power button.
Actually the IR works well until the led code "strip.show();" (strip being of th etype Adafruit_NeoPixel)
is reached, whether the leds are connected or not. Then, the IR return random code, so i cannot turn of the led code by remote controller.
If you have any idea.
Thanks
#include <IRremote.h>
#include <IRremoteInt.h>
#define LED_PIN    4
#define LED_COUNT 12
Adafruit_NeoPixel strip(LED_COUNT, LED_PIN, NEO_GRB + NEO_KHZ800);
IRrecv irrecv(23);
  strip.begin();           // INITIALIZE NeoPixel strip object (REQUIRED)
  strip.show();            // Turn OFF all pixels ASAP
  strip.setBrightness(50); // Set BRIGHTNESS to about 1/5 (max = 255)
  irrecv.enableIRIn(); // Start the receiver
bool lightOn = false;
loop()
  CheckIR();
  if(!lightOn)
    return;
  // Fill along the length of the strip in various colors...
  colorWipe(strip.Color(random(0, 255), random(0, 255), 0), 50);
void CheckIR()
   decode_results results;
  if (irrecv.decode(&results))
    irrecv.resume(); // Receive the next value
    switch (results.value)
        case 0xFFA25D:
            lightOn = !lightOn;
        default:
    }// End Case
void colorWipe(uint32_t color, int wait)
  for (int i = 0; i < strip.numPixels(); i++)
  { // For each pixel in strip...
    strip.setPixelColor(i, color);         //  Set pixel's color (in RAM)
    strip.show();                          //  Update strip to match
