I'm working on a remote switching project. I got it working with push-buttons (i.e. one push-button activates a certain output pin that drives a relay and the other push-button for another pin). I need to implement an IR transmitter and receiver (38kHz) that will operate these two pins (i.e. replace the push-buttons). I have tried some stuff from GitHub and the likes, but it is all much too complicated for me, i'm really no good with programming. Can anyone please provide me with a simple code sample or tutorial that can help me with this? Thanx a lot
Is there any reason you need the iR 38kHz sensors for this? Google will find you examples where iR LEDs are pulsed at lower frequencies to implement a simple optical serial link to a phototransistor at the receiving end. Like this one.
I think using 38KHz is the simpler option. The receiving electronics comes ready-made in a chip, and the use of 38KHz makes the system insensitive to interference from room lighting etc.
dc42:
Sounds reasonable. I'd not tried the other option either, having plenty of the 38KHz chippies on hand I've so far always used that way.
I need to do a project for my vac work, and that is the components given to me in a kit. But i'll check out your link, maybe i could suggest we utilize that instead. Thanx a lot
