Hey
I am currently working on my very first small project.
I'm trying to control an LED strip via IR, my plan was/is to save the signal from the remote control and then send it via the Arduino.
However, I've been stuck for two days and unfortunately, I don't know what the problem is :/.
I have already managed to capture the signal:
“Protocol=NEC Address=0x0 Command=0x45 Raw-Data=0xBA45FF00 32 bits LSB first”
However, sending simply does not work. I can see with my cell phone camera that the LED goes on and off (and if I connect a “normal” LED, it also goes on and off), but the LED strip that I want to control remains off.
I have also tried it with the TV and even holding it directly to it.
I've attached a picture of the approximate setup, unfortunately not the best, as I've never done anything like this before ^^
Please note that the resistance is 100 Ohm and the board I am using is an Elego UNO R3
The funny thing is, when I run the code here I get the answer
“Protocol=Onkyo Address=0x0 Command=0xA200 Raw-Data=0xA2000000 32 bits LSB first”. But isn't that completely wrong? But I also don't know if my idea of sending and receiving at the same time works.
Hope someone can help me somehow, because I am neither an expert nor do I know what else I can try.
Normally you would only need to call myReceiver.enableIRIn(); once in the setup routine but if you are both sending and receiving you have to call it after each send.
I still can not control any devices using the IRLED
Even if I just connect the IR-LED by itself and remove the IR-Reciever.
The LED lights up (which I can see with my camera) but nothing happens
I managed to get it working, but something really weird is happening.
I captured the following IR signal from the remote
Protocol=NEC Address=0x0 Command=0x45 Raw-Data=0xBA45FF00 32 bits LSB first.
However, when I used the following code to send the signal: irsend.sendNEC(0xBA45FF00, 32);
The receiver returned this instead:
Protocol=NEC Address=0x5D Command=0xFF Raw-Data=0xFFA25D 32 bits LSB first
Even though I was explicitly sending 0xBA45FF00, the receiver interpreted it as something completely different.
As a test, I tried sending 0xFFA25D instead: irsend.sendNEC(0xFFA25D, 32);
And surprisingly, the LED strip turned on! The receiver then reported this:
So basically:
Sending 0xBA45FF00 gets interpreted as 0xFFA25D.
Sending 0xFFA25D results in the correct signal, interpreted as 0xBA45FF00.
