IR control of 2 different devices
HI,
I am trying to control 2 different devices via IR. I am using the IRremote library, but I cannot find a solution to use 2 separate IR transmitters. The library only supports one sending pin (in the pin_definicions_and_more). But as my setup requires 2 IR transmitters with different IR protocolls (sendNEC and sendPanasonic) to control 2 different devices, I want to define another sending pin.
All the excamples I found about transmitting IR codes only support one device. But How can I send commands to multiple devices?
I am using an Arduino Uno WiFi Rev2. Attached is the Schematics of how I want to implement it.
Thanks in advance for suggestions!
Rafael
Using tags at tools bar " < code > ", post your atual code.
Also post the link to the IRremote library you are using.
PS:
Read tópic Sending IR codes ---> Send pin
" GitHub - Arduino-IRremote/Arduino-IRremote: Infrared remote library for Arduino: send and receive infrared signals with multiple protocols
I am Using IRremote: GitHub - Arduino-IRremote/Arduino-IRremote: Infrared remote library for Arduino: send and receive infrared signals with multiple protocols
It uses an extra file called PinDefinitionsAndMore.h, which depening on what HW you're using, the send pin. But I cannot find an option to define another send pin. Or disable the macro in the link you're posted.
Here's my code (containing a bit more stuff, that is irrelevant to my issue:
#include <Arduino.h>
#include "PinDefinitionsAndMore.h" // Define macros for input and output pin etc.
#include <IRremote.hpp>
#include <SPI.h>
#include <WiFiNINA.h>
#include <Arduino_JSON.h>
#include "arduino_secrets.h"
uint16_t sAddress = 0x2;
uint8_t sCommand = 0x1D;
uint8_t sRepeats = 2;
char ssid[] = SECRET_SSID;        // your network SSID (name)
char pass[] = SECRET_PASS;    // your network password (use for WPA, or use as key for WEP)
int status = WL_IDLE_STATUS;     // the WiFi radio's status
//  Hue constants
const char hueHubIP[] = "192.168.0.199";  //Hue hub IP
const char hueUsername[] = "Vkkwl2UWz-VMl6JlCgpHBqotGxSgSTkeDAnO1cka";  //Hue username
const int hueHubPort = 80;
//  Hue variables
int hueBri;  // brightness value
long hueHue;  // hue value
String hueCmd;  // Hue command
unsigned long buffer=0;  //buffer for received data storage
unsigned long addr;
//WiFi Client
WiFiClient client;
    pinMode(LED_BUILTIN, OUTPUT);
    Serial.println(F("START " __FILE__ " from " __DATE__ "\r\nUsing library version " VERSION_IRREMOTE));
    IrSender.begin(); // Start with IR_SEND_PIN as send pin and if NO_LED_FEEDBACK_CODE is NOT defined, enable feedback LED at default feedback LED pin
    Serial.print(F("Ready to send IR signals at pin "));
    Serial.println(IR_SEND_PIN);
  // check for the WiFi module:
  if (WiFi.status() == WL_NO_MODULE) {
    Serial.println("Communication with WiFi module failed!");
    // don't continue
    while (true);
  String fv = WiFi.firmwareVersion();
  if (fv < WIFI_FIRMWARE_LATEST_VERSION) {
    Serial.println("Please upgrade the firmware");
  // attempt to connect to WiFi network:
  while (status != WL_CONNECTED) {
    Serial.print("Attempting to connect to WPA SSID: ");
    Serial.println(ssid);
    // Connect to WPA/WPA2 network:
    status = WiFi.begin(ssid, pass);
    // wait 10 seconds for connection:
    delay(10000);
  // you're connected now, so print out the data:
  Serial.print("You're connected to the network");
  printCurrentNet();
  printWifiData();
Serial.println(F("Startup sequence done!"));
  Serial.println(F("*****************"));
  int inputValue = analogRead(A5);
  float Vin = inputValue * (5.0 / 1023.0);
  Serial.print("Input: ");
  Serial.println(Vin);
  if (Vin <= 2) {
    IrSender.sendNEC(sAddress, sCommand, sRepeats);
    Serial.println(F("Power Off Teufel"));
    delay(2000);
    String command = "{\"on\": false}";
    setHue(17,command);
    delay(20000);
  else {
    delay(200);
    Serial.println(F("PC On"));
boolean setHue(int lightNum,String command)
  if (client.connect(hueHubIP, hueHubPort))
    while (client.connected())
      client.print("PUT /api/");
      client.print(hueUsername);
      client.print("/lights/");
      client.print(lightNum);  // hueLight zero based, add 1
      client.println("/state HTTP/1.1");
      client.println("keep-alive");
      client.print("Host: ");
      client.println(hueHubIP);
      client.print("Content-Length: ");
      client.println(command.length());
      client.println("Content-Type: text/plain;charset=UTF-8");
      client.println();  // blank line before body
      client.println(command);  // Hue command
    client.stop();
    return true;  // command executed
void printWifiData() {
  // print your board's IP address:
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
  Serial.println(ip);
  // print your MAC address:
  byte mac[6];
  WiFi.macAddress(mac);
  Serial.print("MAC address: ");
  printMacAddress(mac);
void printCurrentNet() {
  // print the SSID of the network you're attached to:
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  // print the MAC address of the router you're attached to:
  byte bssid[6];
  WiFi.BSSID(bssid);
  Serial.print("BSSID: ");
  printMacAddress(bssid);
  // print the received signal strength:
  long rssi = WiFi.RSSI();
  Serial.print("signal strength (RSSI):");
  Serial.println(rssi);
  // print the encryption type:
  byte encryption = WiFi.encryptionType();
  Serial.print("Encryption Type:");
  Serial.println(encryption, HEX);
void printMacAddress(byte mac[]) {
  for (int i = 5; i >= 0; i--) {
    if (mac[i] < 16) {
      Serial.print("0");
    Serial.print(mac[i], HEX);
    if (i > 0) {
      Serial.print(":");
How do you think manage the universal remotes you can buy, the control of 2 devices with 1 diode?
