IR Empfänger und Nano Fehler beim überprüfen
Hallo zusammen
Ich versuche dieses Projekt nachzubauen. Die Bauteile habe ich mir schon vor einiger Zeit angeschafft, nun möchte ich sie auch benutzen.
* IR Remote Gateway to HomeMatic CUxD
* First you have to setup the IR Lib from : https://github.com/shirriff/Arduino-IRremote
* Thomas Kluge 25092013
#include <IRremote.h>
// used to  map the repeat code fffff
#define userepeat false
//How many codes you are wish to use at max
#define numOfMappedCodes 10
// Learning Mode
#define learning false
// The IR is connected to Arduino Pin 9
int RECV_PIN = 9;
int remoteCodeCounter;  // a Helper
IRrecv irrecv(RECV_PIN); // Initialise the IR Lib
struct mapData {
  unsigned long remoteCode;
  String cuxdCode;
codeMapping[numOfMappedCodes];
decode_results results;
unsigned long lastValue;
// setup Arduino
  setupCodeMapping();
  irrecv.enableIRIn(); // Start the receiver
// a little helper to setup code mapping
void addCodeMapping(unsigned long remoteCode,String cuxdCode) {
 codeMapping[remoteCodeCounter].remoteCode = remoteCode;
 codeMapping[remoteCodeCounter].cuxdCode = cuxdCode;
 remoteCodeCounter++;
// a helper
String cuxdCodeForRemoteCode(unsigned long remoteCode) {
 for (int i=0;i<=remoteCodeCounter;i++) {
 if (codeMapping[i].remoteCode==remoteCode) return codeMapping[i].cuxdCode; }
 return NULL;
// Here you have to setup the mapping between IR Code and CUxD Code
void setupCodeMapping() {
 addCodeMapping(16187647,"FAA000011");
 addCodeMapping(16220287,"FAA000000");
 addCodeMapping(16203967,"FAA000100");
 addCodeMapping(16236607,"FAA000111");
 addCodeMapping(16195807,"FAA000211");
// Main Loop
 if (irrecv.decode(&results)) {
   unsigned long value;
   // Some remotes use FFFFFF to indicate a Press and Hold
   if (results.value==4294967295) {
     value = lastValue;
     if (userepeat) {
      String codeToSend = cuxdCodeForRemoteCode(value);
      if (codeToSend!=NULL)
      Serial.println(codeToSend);
     value = results.value;
     // uncomment the next line if you want to know the IR Code
     if (learning) Serial.println(value);
    lastValue = value;
    if (codeToSend!=NULL) Serial.println(codeToSend);
 irrecv.resume(); // Receive the next value
Leider bekomme ich beim kompillieren immer diese Fehlermeldung
ir_ccu:56: error: converting to 'String' from initializer list would use explicit constructor 'String::String(int, unsigned char)'
C:\Users\xxx\Documents\Arduino\ir_ccu\ir_ccu.ino:56:9: warning: passing NULL to non-pointer argument 1 of 'String::String(int, unsigned char)' [-Wconversion-null]
Kann mir da jemand helfen?
Danke und Gruss
Hansjürg
Hi
Die Funktion gibt einen String zurück, NULL ist kein String.
Änder das NULL Mal in “” (zwei Anführungszeichen ohne Inhalt) - zumindest kompiliert der Sketch dann bei mir.
Allerdings gibt Es einige Warnungen in der Form:
E:\Arduino\sketchbook\libraries\Arduino-IRremote-master\IRremote.cpp: In function 'int MATCH(int, int)':
E:\Arduino\sketchbook\libraries\Arduino-IRremote-master\IRremote.cpp:58:32: warning: suggest braces around empty body in an 'else' statement [-Wempty-body]
     DBG_PRINTLN(F("?; FAILED"));
MfG
Besten Dank, bei mir gibt es keine Fehlermeldung. Ich muss nun aber noch testen ob es auch funktioniert.
Funktioniert :slight_smile:
hafoxx:
Es geht um Warnungen, die in der IDE explizit in Datei/Voreinstellungen eingeschaltet werden müssen, damit man sie sieht. Das ist auf jeden Fall zu enmpfehlen!
