Hey guys,
i got a VISHAY Infrared Led (http://www.vishay.com/ir-emitting-diodes/list/product-81010/) but i dont get it work on my Arduino Mega.
What should i do? Wich resistor shall i use?
Thanks a lot for help!
Hey guys,
You won't be able to run this diode at anything like its designed ratings directly from the Arduino - you'll need to use a transistor.
how should i do that? could you explain how to buil that wiring?
May anybody help me?
This really is basic stuff, the kind you learn from a little effort on your part.
You have given us almost no information whatsoever about what you are trying to accomplish so I am left only assuming your trying to pulse this led to mimic some sort of ir communication device.
Here is an example I quickly found using google (Google should always be your first reference when asking a question)
http://www.electronicsteacher.com/tutorial/learning-to-use-leds-and-transistors.php
joconcepts, the other guys are right, to run the LED to its full potential (read: range), you will need a transitor and a 5V supply capable of 100+mA.
But you should be able to get it to work without any of that. I have the a Vishay TSAL5300 (a similar LED to the one you have) and I was able to use it to control my TV. I connected it to a PWM pin 3 via a 270ohm resistor and it worked; the range, as expected, was tiny (~5cm). But that was more than good enough to test my program worked.
Edit: and if you are trying to recreate an IR blaster of a Hifi rack then 5cm is more than enough range (considering most blasters have the led touching the devices sensor)
Note that 100mA is the maximum continuous rating.
You'll probably be pulsing, so the instantaneous current could be much higher, depending on duty-cycle.
As always, check the datasheet.
