IR LED send different code from the one written in sketch
Hello, I am facing a problem and I hope I can find a solution here.
I am trying to turn on/off by Blynk using NodeMCU ESP8266.
I could successfully read the IR signal (code) from the Remote Controller of the TV, but when I tried to send the IR code to the TV through IR LED, TV didn't response.
So I decided to combine the sketch of IR receive and the sketch of IRsend into one sketch so when I click on the V2 Button of Blynk, I can read the signal that is coming from the IR LED and then compare it with the original signal of RC of TV.
What I found is: the code coming from the IR LED is different from the one that I wrote in the sketch, (which is the original code of RC of TV)
These two images will explain what I mean:
So now I know the reason of why TV is not responding to my Blynk (cuz the IR code is changing)
So my question is why IR LED is sending different code from the one written in sketch? Is it something wrong in the code?
I would also add that I tired to send the code using both rawdData code and normal code.
This is my circuit that I am using if it helps in my problem( JUST IR LED AND IR RECEIVER )
My Code
#include <ESP8266WiFi.h>
#include <BlynkSimpleEsp8266.h>
#include <IRremoteESP8266.h>
char auth[] = "xxx";
char ssid[] = "xxx";
char pass[] = "xxx";
int khz = 38; // 38kHz carrier frequency for both NEC and Samsung
int RECV_PIN = 2; //an IR detector/demodulator is connected to GPIO pin 2
IRsend irsend(0); //an IR led is connected to GPIO4 (pin D2 on NodeMCU)
IRrecv irrecv(RECV_PIN);
  // Insert RAW IR signal for "TV Power"
unsigned int irTVpwr[66] = {4550,550, 600,550, 650,550, 650,550, 650,550, 650,550, 650,550, 650,550, 650,550, 650,550, 650,550, 650,550, 650,550, 1750,550, 650,550, 650,500, 650,550, 1750,550, 650,550, 650,550, 650,550, 1750,550, 650,550, 650,550, 650,550, 650,550, 1750,550, 1750,550, 1750,550, 650,550, 1750,550, 1750,550, 1750,550};// NEC 4FFE01F
  delay(5000);
  Blynk.begin(auth, ssid, pass);
  irsend.begin();
  irrecv.enableIRIn();  // Start the receiver
void  ircode (decode_results *results)
  // Panasonic has an Address
  if (results->decode_type == PANASONIC) {
    Serial.print(results->panasonicAddress, HEX);
    Serial.print(":");
  // Print Code
  Serial.print(results->value, HEX);
// Display encoding type
void  encoding (decode_results *results)
  switch (results->decode_type) {
    default:
    case UNKNOWN:      Serial.print("UNKNOWN");       break ;
    case NEC:          Serial.print("NEC");           break ;
    case SONY:         Serial.print("SONY");          break ;
    case RC5:          Serial.print("RC5");           break ;
    case RC6:          Serial.print("RC6");           break ;
    case DISH:         Serial.print("DISH");          break ;
    case SHARP:        Serial.print("SHARP");         break ;
    case JVC:          Serial.print("JVC");           break ;
    case SANYO:        Serial.print("SANYO");         break ;
    case MITSUBISHI:   Serial.print("MITSUBISHI");    break ;
    case SAMSUNG:      Serial.print("SAMSUNG");       break ;
    case LG:           Serial.print("LG");            break ;
    case WHYNTER:      Serial.print("WHYNTER");       break ;
    case AIWA_RC_T501: Serial.print("AIWA_RC_T501");  break ;
    case PANASONIC:    Serial.print("PANASONIC");     break ;
// Dump out the decode_results structure.
void  dumpInfo (decode_results *results)
  // Show Encoding standard
  Serial.print("Encoding  : ");
  encoding(results);
  Serial.println("");
  // Show Code & length
  Serial.print("Code      : ");
  ircode(results);
  Serial.print(" (");
  Serial.print(results->bits, DEC);
  Serial.println(" bits)");
void  dumpRaw (decode_results *results)
  // Print Raw data
  Serial.print("Timing[");
  Serial.print(results->rawlen-1, DEC);
  Serial.println("]: ");
  for (int i = 1;  i < results->rawlen;  i++) {
    unsigned long  x = results->rawbuf[i] * USECPERTICK;
    if (!(i & 1)) {  // even
      Serial.print("-");
      if (x < 1000)  Serial.print(" ") ;
      if (x < 100)   Serial.print(" ") ;
      Serial.print(x, DEC);
    } else {  // odd
      Serial.print("     ");
      Serial.print("+");
      if (i < results->rawlen-1) Serial.print(", "); //',' not needed for last one
    if (!(i % 8))  Serial.println("");
  Serial.println("");                    // Newline
void  dumpCode (decode_results *results)
  // Start declaration
  Serial.print("unsigned int  ");          // variable type
  Serial.print("rawData[");                // array name
  Serial.print(results->rawlen - 1, DEC);  // array size
  Serial.print("] = {");                   // Start declaration
  // Dump data
    Serial.print(results->rawbuf[i] * USECPERTICK, DEC);
    if ( i < results->rawlen-1 ) Serial.print(","); // ',' not needed on last one
    if (!(i & 1))  Serial.print(" ");
  // End declaration
  Serial.print("};");  //
  // Comment
  Serial.print("  // ");
  encoding(results);
  Serial.print(" ");
  ircode(results);
  // Newline
  Serial.println("");
  // Now dump "known" codes
  if (results->decode_type != UNKNOWN) {
    // Some protocols have an address
      Serial.print("unsigned int  addr = 0x");
      Serial.println(";");
    // All protocols have data
    Serial.print("unsigned int  data = 0x");
// The repeating section of the code
    Blynk.run();
    decode_results  results;        // Somewhere to store the results
  if (irrecv.decode(&results)) {  // Grab an IR code
    dumpInfo(&results);           // Output the results
    dumpRaw(&results);            // Output the results in RAW format
    dumpCode(&results);           // Output the results as source code
    Serial.println("");           // Blank line between entries
    irrecv.resume();              // Prepare for the next value
  BLYNK_WRITE(V2)
  if (param.asInt()){
    irsend.sendRaw(irTVpwr, sizeof(irTVpwr) / sizeof(irTVpwr[0]), khz);
    irsend.sendNEC(62586763, 32);
    //delay(40);
