IR LED sensor
Hi!
I have been buildning an IR communication link between my arduino unos from scratch, but I've run in to a problem. I don't know if the sensor I am using is fast enough. The fastest reliable reaction I can get from it is about 3ms at a 10mm distance.
digitalWrite(dataPin,state);
delay(3);
Serial.print(analogRead(A0));
Serial.println(digitalRead(dataPin));
state = !state;
This is my sensor: Dropbox - Public - Simplify your life
When I was testing it in the beginning, I found that the higher resistance I used the more sensitive the sensor got. Right now it's using a 1.42MOhm resistor.
Is this setup good or really wrong? I've just been going by trial an error really :stuck_out_tongue:
delay(3);
Sorry if I wasn't clear enough.
const int dataOutPin = 7;
const int dataInPin = 6;
boolean state = LOW;
void setup(){
  pinMode(dataOutPin,OUTPUT);
  pinMode(dataInPin,INPUT);
void loop(){
  digitalWrite(dataOutPin,state);
  delay(3);
  Serial.print(" ");
  Serial.println(digitalRead(dataInPin));
With this code the serial shows correct 1's and 0's. but with "delay(2)" instead the bits are not always correct.
I just wanted to know if my sensor is a good setup, or if there is a much better circuit?
Are you sure you're using a photodiode and not an LDR?
