IR LED - Which would use less power?
I don't own a uCurrent (and can't afford one); I have no good way of measuring low amperages. (I am contemplating building one over time)
That said; I want to run something on batteries, but (of course) want it to run forever. I have done a lot to get it down...
But, I am running an IR LED to send a single IR code periodically.
Currently, I have it (see attached, lower schematic) run it directly off the arduino pin. This is working.
But, the (see attached, upper schematic) "proper way" has been suggested may be better in power usage.
The difference that I can tell is: the LED would be taking power directly from the batteries (3 AA) instead of thru the arduino regulator.
"KISS" tells me to leave it as is; but if the proper way would yield longer battery life, I'd happily go with that.
Any ideas which will perform better, battery wise?
Thank you.
(Bonus Question: If you use KiCad, how can I get resistors to show up with more conventional zig-zag line?)
Forgot to add the image...
The diode is the wrong way around in the upper circuit.
It does not really matter whether you drive the LED with an additional transistor. Power consumption will be proportional to the LED current. And you will need a certain current to have the LED send over a given distance. First try to determine which minimal current is necessary for your hardware setup. Then adjust the current with a reasonable margin (maybe 150%) for reliable transmission.
BTW when using three AAs you do not need a regulator. Get rid of the Arduino board and build a stand alone circuit. This will save MUCH energy
Agree.
Even when not transmitting the arduino will be drawing significant power.
Dedicated chips draw zero power until the button is pressed and can run off a coin cell.
If this has to be automatic investigate how to put the arduino into sleep mode.
If a regular pulse , you may consider a low power 555 timer circuit, it will draw much less than an arduino.
Thanks!
@olf2012 - re:diode: Sorry about that -- I was trying to get the schematic done quickly to post so I wasn't hit with "a schematic please"... I am still working out think with kicad; some things are just not intuitive.
So far I can put a 480ohm resistor and it works. Going to 1K it started to get flakey if the sun was really bright.
I have supplied power to "raw" pin, I thought this bypassed the regulator; but I can remote the regulator as well. (I already removed the 'power is on' led)
@Boardburner2 - I am using rocketscreams "low power" library; here's my setup; then my delay does go to sleep...
 power_adc_disable(); // ADC converter
  power_spi_disable(); // SPI
  power_usart0_disable();// Serial (USART)
  //power_timer0_disable();// Timer 0
  //power_timer1_disable();// Timer 1
  //power_timer2_disable();// Timer 2
  power_twi_disable(); // TWI (I2C)
I haven't disabled a timer, because I hadn't yet looked to see which timer irRemote uses.
and where I would use a delay() I am using my own function that takes seconds (not milliseconds) to sleep for most of the time:
void mySleepyDelay( int delayTimeSeconds ){
  unsigned int secondsPassed=0;
  while( secondsPassed < delayTimeSeconds ) {
    LowPower.powerDown(SLEEP_8S, ADC_OFF, BOD_OFF);
    secondsPassed += 8;
(yes, I know it can go up to 8 seconds beyond, but I'm sleeping for 1.5 hours, not seconds, so it's not a critical timing.
I had considered using a 555 timer; but I couldn't easily figure out how to get it power on the arduino long enough for it to run a sketch. I got it to use be an external interrupt to wake it out deep sleep instead of the 8second timer. Since I can't measure low ma's I couldn't tell if that saved me anything as I was now powering 2 things instead of just 1.
More and more that uCurrent is looking like a must-have. I should play with my cheap oscilloscope (dpscope ii) to see if I can use it to measure sub-ma's.
daveyjones:
I will leave the software for the more capable.
You could use a simple latch which the 555 fires up, then use an arduino output to switch it off when it has done its job.
I was thinking that a dedicated remote chip with a 555 would work.
Arduino would be more flexible though.
daveyjones:
I have a microamp lab meter that has not left the cupboard in 20 years.
Google on VU meter.
Analog ones with 200 uA fsd can be had.
Never needed anything else .
You need to understand kirchoffs laws though to use them properly.
Thanks. I'll have a look at 555 latching circuits.
Thanks for the idea!
Microamps are measured using a resistor and a voltmeter! That's how any multimeter does it, and
you can do this with another Arduino's analog inputs if you want! 1uA through 10k gived 10mV...
Even cheap multimeters can do this with a resolution of 0.1uA. You can even get mechanical
microammeters with 0..50uA full scale (though they will not tolerate over current and are easy to damage).
cool! I'll try to find an example of how to set this up after classes.
thanks
Boardburner2:
Well; I searched for 555 latch circuit and came up with a dizzying array of various solutions...
I'm sure the time would be well spent to learn the ins and outs of the 555; but for now I am going to shelve it -- I couldn't find something that would turn on the arduino until the arduino says "turn off".
I can see a possible mid--way solution, but again, w/o being able to measure the low current; I'm not sure it'd be worth the effort.
Use the 555 to send an external interrupt to wake up the arduino every X minutes (ideally 90 or more), and the arduino just treat it as an interrupt; do it's job; then go back to deep sleep "forever".
but I think getting the 555 to turn it on & wait for the 555 to get a signal "I'm done" and turn it off would be better, based on what I have seen on 555 specs on power usage...
if you have circuit/schematic in mind or a good place to hunt one down; I would really appreciate it.
Off to class.
Here is a start
http://forum.arduino.cc/index.php?topic=328109.0
Possibly investigating using an external (programmable) interrupt timer as well.
EDIT
This circuit may be better as it only requires momentary contact to tyrn it on.
http://forum.arduino.cc/index.php?topic=373255.15
Atmel chips can run at 1uA in sleep mode.
Its the perhipherals that you cannot turn off in software which take the current.
Discussed in the thread i linked.
Crossroads has some bare bones boards which get around this problem.
Thanks! I will read over the links; Thank you so much those.
On 1st glance it seems two things I need to learn -- the latching circuit which will turn on the microprocessor; and a 555 circuit that will 'turn on' the latching circuit (which then turns on the mcp).
When I was reading the 555 (on my own) I was trying to find something relevant that had a single 555 circuit that did everything.. Now it makes much more sense.
So the 555 circuit will need to be tuned to signal every 90 (or so) minutes for a brief period. The latching circuit and arduino takes care of turning off.
The 2nd part seems very straight forward; the tuning ('programming') of the 555 will be the hard part (for me -- but I get the idea now; and there's lots of pages out there, so I'm sure I'll get the formula to figure it out)
Thank you!
Not sure why you want to use a 555.
Don't forget that a common 555 uses ~5mA idle, and won't work below 4.5volt.
It can sink some current at that low voltage, but not source.
A Cmos 555 can work at a lower voltage, uses 60-200uA idle, but can't drive/switch much at low voltages.
What are you planning to do with this intermittend 'IR code'.
Leo..
a CSS555 would be much better for consumption.
More work for the op to understand though.
Boardburner2:
As said, little output current (pin3) available at low (battery) voltages.
Only the 'discharge' pin of a cmos 555 can sink enough current to drive/modulate an IR LED at low supply voltages. Example attached is a continious mode 5meter curling game 'beambreak' ~38kHz IR transmitter I designed some time ago. Works on 2x AA for a looong time. LED/resistor to the left is a battery indicator, and is not needed to function.
Leo..
That's what was suggested. (FWIW the only 555 I have here is a cmos version)
Although, after reading today; I ordered up a few 4541's they seemed more like something that was usable for the long duration.
It's a project for my uncle..
Dish recently forced us to upgrade satelite receivers. This new receiver shuts off after 4 hours of no use. (there is a setting, which is currently 'disabled', but it still goes to sleep). He tried dealing with them but he got nowhere dealing with dish. It was trivial enough to build a small thing to send the "power on" code every x hours. (it's working fine) --I just want to reduce the power more so it can last longer on batteries. (we want it to stay on, so the dvr can record things; we don't want enough tv that 'normal use' would keep the receiver watchdog from going to sleep...)
daveyjones:
Understood. Bloody nuisance compulsary power savings "feature".
My Samsung TV also does that e.g. when I'm watching a long movie.
"Press a button within 1 minute, otherwise I will enter standby" Grrrr.
Or when I turn my PC/media player off: "You have unplugged the HDMI cable".
I wonder if the people why design those things ever watch TV.
Can't you use e.g. a Nano and a 5volt phone charger with micro-USB lead.
A phone charger runs on fumes. Batteries are expensive
Sleep the Nano if you want to, or use it also for something else e.g. temp display or fancy TV background lighting.
Leo..
Wawa:
Leo..
It was not for driving a led, the output drives a latch to switch on an arduino supply which then drove the led before switching off the latch.
daveyjones:
The CSS555 is better for battery app, same quiescent current but works down to a couple of volts.
