IR library help
i want to get two decode values from two sensors at the same time
any one know how to do it with this code
  • IRremote: IRrecvDemo - demonstrates receiving IR codes with IRrecv
  • An IR detector/demodulator must be connected to the input RECV_PIN.
  • Version 0.1 July, 2009
  • Copyright 2009 Ken Shirriff
  • http://arcfn.com
#include <IRremote.h>
int RECV_PIN = 11;
IRrecv irrecv(RECV_PIN);
decode_results results;
irrecv.enableIRIn(); // Start the receiver
if (irrecv.decode(&results)) {
Serial.println(results.value, HEX);
irrecv.resume(); // Receive the next value
delay(100);
Use two Arduinos.
At the same time?
The IR signals will interfere with each other.
PaulS:
Use two Arduinos.
:confused:
no any method??
LarryD:
At the same time?
nope
it will give decode results
nope
Well then, since you are sure that it can be done (it can't), go right ahead.
The IR library uses a timer to decode the incoming data. A timer means ONE timer. The same timer every time. Two instances of the class will use the SAME timer and the instances WILL interfere.
PaulS:
oops....
anyhow i found another way
thanks :slight_smile:
