IR Library not working with IDE 1.6.1 - Linux + Arduino Uno
I wanted to do some IR work again using an UNO. I used the IDE 1.0.1 the last time.
Is https://github.com/shirriff/Arduino-IRremote still used to implement IR read and send?
1885
Error:
Build options changed, rebuilding all
/home/cwc/arduino-1.6.1/libraries/RobotIRremote/src/IRremoteTools.cpp:5:16: error: ‘TKD2’ was not declared in this scope
int RECV_PIN = TKD2; // the pin the IR receiver is connected to
Error compiling.
Here is the example code from:
#include <IRremote.h>
int RECV_PIN = 11;
IRrecv irrecv(RECV_PIN);
decode_results results;
irrecv.enableIRIn(); // Start the receiver
if (irrecv.decode(&results)) {
Serial.println(results.value, HEX);
irrecv.resume(); // Receive the next value
You told Arduino to use IRremote but it got that mixed up with the built-in RobotIRremote. I don't know how to work around that problem.
i'm also facing same problem ..
