IR Obstacle Sensor Coding Problem
hello, I am new to Arduino, I was Looking to make an obstacle avoider/line follower robo using arduino and IR OBSTACLE SENSOR.
I bought a couple of digital ir obstacle sensor, and tried to test them,,, I made a simple code and uploaded it to the arduino,.
the basic logic is, when obstacle is there, the led will blink and serial monior will show :- "obstacle"... otherwise the serial monitor will show:-"go",,,,,,,
when I uploaded the code the led was blinking, but there was no message shown in the serial monitor. Also when I tried using it on the robo, only the line next to the "if statement" is executed.
Can you please tell me what the problem is.here is the code:-
int irpin=7;
int led=13;
int obs=HIGH;
pinMode(irpin,INPUT);
obs=digitalRead(irpin);
if(obs==HIGH){
digitalWrite(led,HIGH);
delay(200);
digitalWrite(led,LOW);
Serial.println("obstacle");// this line does not executes
else{
Serial.println("go");//this line does not executes
code is OK. Add 'serial.begin(your speed)' in setup
