IR obstacle sensor range
Hello everybody
I have this IR obstacle sensor https://hacktronics.co.in/obstacle-detection/smart-car-infrared-ir-obstacle-detection-sensor
When I turn the potentiometer knob at some point the detection LED is always on even tho i haven't turned the knob till the maximum not even near it the current distance im getting is roughly 10-15 cm while i need it to be atleast 25 cm
im connecting directly to the arduino due 5 volts pin if anyone knows how I can fix that it'll be much appreciated.
Thank you :slight_smile:
Remove all ambient IR (switch off the lights; remove any warm/hot objects including people).
If that doesn't work: get a better sensor.
