IR Output help
Hello, I connected RFID, LCD, SERVO (ignore this), and i connected everything right and it works. Now I have the problem, as you see at the very end of the code there is if statement checking if specific signal is received, it doesn’t work, Can you Help me?
#include <IRremote.h>
#include <SPI.h>
#include <MFRC522.h>
#include <Servo.h>
#include <LiquidCrystal.h>
const int RECV_PIN = A1;
IRrecv irrecv(RECV_PIN);
decode_results results;
#define SS_PIN 10
#define RST_PIN 9
#define SERVO_PIN 8
Servo myservo;
 // GREEN CABLE +UP = 5V    RED-BLACK CABLE +UP = GND
#define ACCESS_DELAY 2000
#define DENIED_DELAY 1000
MFRC522 mfrc522(SS_PIN, RST_PIN);   // Create MFRC522 instance.
const int rs = 7, en = 6, d4 = 5, d5 = 4, d6 = 3, d7 = 2;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
  irrecv.enableIRIn();
  irrecv.blink13(true);
  myservo.attach(SERVO_PIN);
  myservo.write( 70 );
  lcd.begin(16, 2);
  Serial.begin(9600);   // Initiate a serial communication
  SPI.begin();          // Initiate  SPI bus
  mfrc522.PCD_Init();   // Initiate MFRC522
  Serial.println("Put your card to the reader...");
  lcd.setCursor(0, 0);
  lcd.print("Loading");
  // print the number of seconds since reset:
  lcd.clear();
  lcd.print("Loading.");
  lcd.clear();
  lcd.print("Loading..");
  lcd.clear();
  lcd.print("Loading...");
  lcd.clear();
  lcd.clear();
  lcd.clear();
  lcd.clear();
  lcd.clear();
  lcd.print("Enter your Card.");
  myservo.write( 1 );
  if (irrecv.decode(&results)){
        Serial.println(results.value, HEX);
        irrecv.resume();
  // Look for new cards
  if ( ! mfrc522.PICC_IsNewCardPresent())
    return;
  // Select one of the cards
  if ( ! mfrc522.PICC_ReadCardSerial())
    return;
  //Show UID on serial monitor
  Serial.print("UID tag :");
  String content = "";
  byte letter;
  for (byte i = 0; i < mfrc522.uid.size; i++)
    Serial.print(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " ");
    Serial.print(mfrc522.uid.uidByte[i], HEX);
    content.concat(String(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " "));
    content.concat(String(mfrc522.uid.uidByte[i], HEX));
  Serial.print("Message : ");
  content.toUpperCase();
  if (content.substring(1) == "BA 41 82 3B") //change here the UID of the card
    Serial.println("Authorized access.");
    lcd.clear();
    lcd.setCursor(0, 2);
    lcd.write("  Authorized!");
    delay(7500);
    myservo.write( 1 );
    lcd.clear();
    lcd.write("Enter your Card.");
  else   {
    Serial.println(" Access denied");
    lcd.clear();
    lcd.write(" Access Denied.");
    delay(1500);
    lcd.clear();
    delay(DENIED_DELAY);
  } // starting from here
  if (irrecv.decode(&results)) {
    if ((results.value, HEX) == "FFA857" {
    lcd.clear();
    lcd.write("code 1");
    irrecv.resume();
I don't somehow think that results.value is a string, nor should you invent syntax in an attempt to convert it into HEX
Try this
   if (results.value == 0xFFA857)
UKHeliBob:
Try this
Yeah, you're right but non-converted codes looks like - 1468455
tried to work but looks like no effect
    if (results.value == 16754775) {
    lcd.clear();
    irrecv.resume();
EDIT: Fixed code - thank you! You helped me alot!
1468455 is in decimal
0xFFA857 is the same number expressed in Hex
The compiler doesn't care as it sees it in binary (0b1111 1111 1010 1000 0101 0111‬) anyway
