I am trying locate a simple, very simple, IR remote switch that will work with any remote transmitter to power Arduino on and off. Is there anything easier than this? http://www.zen22142.zen.co.uk/Circuits/Interface/ir_switch.htm
you should be able to adapt this to do it http://www.instructables.com/id/IR-Detector/
edit:
You could use the fototransisor with a relay that will stay in its sate when electricity is disconected,
Example: fototransisor detects uv, power gose to relay. Relay allows power through, then when the fototransisor resives more uv, the relay snaps back and thus no more power
Yes, that seems to be a much better solution. I'll give it a try. Thank you.
