IR Raw code problem
Hi everyone,
I wanna explain my problem about the IR LED. My idea is to control the A/C in my room with Arduino with IR LED. Right now I'm able to control my Samsung TV without any problem. With A/C I'm facing some problems, instead. This is what I get when I use the receiver on PIN 11 with my remote control DaiKin ARC4333:
B3E2CB06
Unknown encoding: B3E2CB06 (32 bits)
Raw (12): 5492 600 -250 600 -250 600 -250 600 -250 600 -300 550
FFFFFFFF
FFFFFFFF (0 bits)
Raw (132): 30936 3400 -1750 350 -1350 400 -450 400 -450 400 -450 400 -1300 400 -450 400 -450 400 -450 400 -500 350 -1350 400 -450 400 -1300 400 -1300 400 -450 400 -1300 400 -1350 350 -1350 400 -1300 400 -1300 400 -450 400 -450 400 -1350 350 -500 350 -500 400 -450 400 -450 400 -450 400 -450 400 -450 400 -450 400 -450 400 -450 400 -500 350 -1350 400 -450 400 -450 400 -450 400 -450 400 -1300 400 -450 400 -450 400 -500 350 -500 400 -450 350 -500 400 -450 400 -450 400 -450 400 -450 400 -450 400 -450 400 -450 400 -500 350 -500 350 -500 400 -450 400 -450 400 -450 400 -1300 400 -450 400 -1300 400 -500 350 -1350 400 -450 400
I cannot control the A/C. Do you have any idea ?hank you in advance for your answers.
Did you google daikin ac ir codes
Tom... :slight_smile:
Thanks Tom,
But I want to control the A/C by arduino? I cannot decode Daikin A/C? Can anybody help me?
Thanks
Kid
Some A/C codes are very long and don't fit in the default buffer of the IRremote library. You can change the size of RAWBUF in IRremoteInt.h to allow for longer codes. Try increasing the value until you can record and play back the codes.
I changed the size of RAWBUF in IRremoteInt.h but nothing change. Do you have any ideas?
What did you change it to? Did the output still say:
