ir receive code blocked by bt serial how to fix?
my receive code is blocked when connect to my bt serial code. how to program the ir receive code so that it works in harmony with the bt serial?
#include <IRremote.h>
#define PIN 6
Adafruit_NeoPixel strip = Adafruit_NeoPixel(11 * 1, PIN, NEO_GRB + NEO_KHZ800);
IRsend irsend;//TX, RX respetively
String readdata;
int vSpeed = 100;
int RECV_PIN = 2;
IRrecv irrecv(RECV_PIN);
decode_results results;
Serial1.begin(9600);
strip.begin();
strip.show();
irrecv.enableIRIn();
pinMode(12, OUTPUT);
pinMode(10, OUTPUT);
pinMode(5, OUTPUT);
pinMode(11, OUTPUT);
colorWipe(strip.Color(0, 0, 255), 10);
void loop(void) {
while (Serial1.available()) { //Check if there is an available byte to read
delay(10); //Delay added to make thing stable
char c = Serial1.read(); //Conduct a serial read
readdata += c; //build the string- “forward”, “reverse”, “left” and “right”
if (readdata.length() > 0) {
Serial.println(readdata);
if (readdata == “forward”)
analogWrite(10, vSpeed);
analogWrite (12, LOW);
analogWrite(5, vSpeed);
analogWrite(11, LOW);
delay(100);
else if (readdata == “back”)
analogWrite(10, LOW);
analogWrite(12, vSpeed);
analogWrite(5, LOW);
analogWrite(11, vSpeed);
delay(100);
else if (readdata == “right”)
analogWrite (10, vSpeed);
analogWrite (5, LOW);
analogWrite (11, LOW);
delay (100);
else if ( readdata == “left”)
analogWrite (10, LOW);
analogWrite (12, HIGH);
analogWrite (5, vSpeed);
delay (100);
else if ( readdata == “reload”)
rainbowCycle(5);
else if (readdata == “stop”)
digitalWrite (10, LOW);
digitalWrite (12, LOW);
digitalWrite (5, LOW);
digitalWrite (11, LOW);
delay (100);
else if (readdata == “shoot”)
irsend.sendNEC(0x189710EF, 32);
delay(40);
readdata = “”;
//Reset the variable
if (irrecv.decode(&results)) {
Serial.println(results.value, HEX);
if (results.value == 0xFF30CF) {
Serial.println(“Button1”);
colorWipe(strip.Color(255, 0, 0), 1); // Red
delay(100);
irrecv.resume(); // Receive the next value
delay(100);
void colorWipe(uint32_t c, uint8_t wait) {
for (uint16_t i = 0; i < strip.numPixels(); i++) {
#ifdef DEBUG
Serial.print(“set pixel “);
Serial.print(i);
Serial.print(” of “);
Serial.print(strip.numPixels());
#endif
strip.setPixelColor(i, c);
#ifdef DEBUG
Serial.println(” - ok”);
#endif
//delay(wait);
strip.show();
void rainbow(uint8_t wait) {
uint16_t i, j;
for (j = 0; j < 256; j++) {
for (i = 0; i < strip.numPixels(); i++) {
strip.setPixelColor(i, Wheel((i + j) & 255));
strip.show();
delay(wait);
// Slightly different, this makes the rainbow equally distributed throughout
void rainbowCycle(uint8_t wait) {
uint16_t i, j;
for (j = 0; j < 256 * 5; j++) { // 5 cycles of all colors on wheel
strip.setPixelColor(i, Wheel(((i * 256 / strip.numPixels()) + j) & 255));
strip.show();
delay(wait);
//Theatre-style crawling lights.
void theaterChase(uint32_t c, uint8_t wait) {
for (int j = 0; j < 10; j++) { //do 10 cycles of chasing
for (int q = 0; q < 3; q++) {
for (int i = 0; i < strip.numPixels(); i = i + 3) {
strip.setPixelColor(i + q, c); //turn every third pixel on
strip.show();
delay(wait);
strip.setPixelColor(i + q, 0); //turn every third pixel off
//Theatre-style crawling lights with rainbow effect
void theaterChaseRainbow(uint8_t wait) {
for (int j = 0; j < 256; j++) { // cycle all 256 colors in the wheel
strip.setPixelColor(i + q, Wheel( (i + j) % 255)); //turn every third pixel on
strip.show();
delay(wait);
// Input a value 0 to 255 to get a color value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
if (WheelPos < 85) {
return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
} else if (WheelPos < 170) {
WheelPos -= 85;
return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
WheelPos -= 170;
return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
IRremote uses Timer2 by default and that is also used for PWM on pins 9 and 10. Since you are using Pin 10 for PWM output that is causing a conflict. Read more about the IRremote library to see how to select a different timer.
And STOP POSTING THE SAME QUESTION OVER AND OVER!
