IR receiver doesn't work with Adafruit led strip
I have a led strip and an IR receiver connected.
When adding led strip controls, the IR reading does not work. -> "Decoded Unknown(0): Value:0 Adrs:0 (0 bits)"
Just commenting out "valot()" in main loop makes the IR work again. -> Decoded NEC(1): Value:FFA25D Adrs:0 (32 bits)
16753245
CH-
The led strip alone can be properly controlled by Arduino (by altering the variables by hand, randomly, incrementally, etc).
Can you help?
#include "IRLibAll.h"
#define CHnappi 16736925
#define CHplus 16769565
#define CHminus 16753245
//Create a receiver object to listen on pin 2
IRrecvPCI myReceiver(2);
//Create a decoder object
IRdecode myDecoder;
// Define the number of LEDs
#define NUM_LEDS 20
// Define SPI Pin
#define PIN A1
// Baudrate, higher rate allows faster refresh rate and more LEDs (defined in /etc/boblight.conf)
#define serialRate 115200
//// End of user definitions /////
// Utilises FastSPI_LED2
#define FORCE_SOFTWARE_SPI
#define FORCE_SOFTWARE_PINS
#include <FastSPI_LED2.h>
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUM_LEDS, PIN, NEO_GRB + NEO_KHZ800);
// Adalight sends a "Magic Word" (defined in /etc/boblight.conf) before sending the pixel data
uint8_t prefix[] = {'A', 'd', 'a'}, hi, lo, chk, i;
// initialise LED-array
CRGB leds[NUM_LEDS];
int B = 1;
int h = 255;
int s = 30;
int v = 200;
int hue = 55;
int sat = 30;
int val = 20;
int pun, vih, sini;
int r, g, b;
unsigned long prev;
  myReceiver.enableIRIn(); // Start the receiver
  Serial.println(F("Ready to receive IR signals"));
  pinMode(A0, INPUT_PULLUP);
  FastLED.addLeds<WS2812, PIN, RGB>(leds, NUM_LEDS);
  if (millis() > prev + 100 && digitalRead(A0) == LOW) {
    prev = millis();
    off();
  kauko();
 // HSV_to_RGB(hue, sat, val);
  Serial.println(r);
  Serial.println(g);
  Serial.println(b);
  Serial.println(hue);
  Serial.println(sat);
  Serial.println(val);
    valot();
  //  delay(2000);
void kauko() {
  if (myReceiver.getResults()) {
    myDecoder.decode();           //Decode it
    myDecoder.dumpResults(false);  //Now print results. Use false for less detail
    Serial.println(myDecoder.value);
    switch (myDecoder.value) {
      case CHnappi:
        hue = hue + 20;
        if (hue >= 360)hue = 0;
        Serial.println("CH");
      case CHplus:
        val += 10;
        if(val>=100)val=100;
        Serial.println("CH+");
      case CHminus:
        val -= 10;
        if(val<=0)val=0;
        Serial.println("CH-");
    myReceiver.enableIRIn();      //Restart receiver
void off() {
  B = !B;
void valot()
  for (int i = 0; i < NUM_LEDS; i++) {
    // strip.setPixelColor(i, strip.Color(pun * B, vih * B, sini * B));
    strip.setPixelColor(i, strip.Color(r * B, g * B, b * B));
    strip.show(); // This sends the updated pixel color to the hardware.
  // delay(100);
void HSV_to_RGB(float h, float s, float v)
  int i;
  float f, p, q, t;
  h = max(0.0, min(360.0, h));
  s = max(0.0, min(100.0, s));
  v = max(0.0, min(100.0, v));
  s /= 100;
  v /= 100;
  if (s == 0) {
    // Achromatic (grey)
    r = g = b = round(v * 255);
    return;
  h /= 60; // sector 0 to 5
  i = floor(h);
  f = h - i; // factorial part of h
  p = v * (1 - s);
  q = v * (1 - s * f);
  t = v * (1 - s * (1 - f));
  switch (i) {
    case 0:
      r = round(255 * v);
      g = round(255 * t);
      b = round(255 * p);
    case 1:
      r = round(255 * q);
      g = round(255 * v);
      b = round(255 * p);
    case 2:
      r = round(255 * p);
      g = round(255 * v);
      b = round(255 * t);
    case 3:
      r = round(255 * p);
      g = round(255 * q);
      b = round(255 * v);
    case 4:
      r = round(255 * t);
      g = round(255 * p);
      b = round(255 * v);
    default: // case 5:
      r = round(255 * v);
      g = round(255 * p);
      b = round(255 * q);
It works if I call the function valot() after this line:
The NeoPixel library usually disable interrupts to drive WS281x LEDs. This can interfere with anything else using interrupts. Does the IR library use interrupts? If so, that might explain why both cannot be used at the same time.
Yes, that must be it. Thanks!
