IR receiver, electrical noise?
I have a CHQ 1838 IR receiver. When the Arduino Uno receives an unknown code and re-sends it raw, something triggers the receiver again. (When a known code is received, re-sending doesn't trigger the receiver.) I thought it was light from the IR LED, but I by-passed the IR LED and the receiver is still triggered. If I disconnect the output circuit completely, no problem. The IR LED is connected through a 2N3904 transistor.
So...electrical noise from the output circuit feeding back into the receiver?
The receiver has a 10k resistor between Vcc and the Out pin.
Notice where the following reads "Sent raw" then "Received unknown code, saving as raw" immediately after.
Decoded Unknown(0): Value:0 (0 bits)
Raw samples(100): Gap:23848
Head: m3350 s1800
0:m350 s500 1:m350 s1400 2:m300 s550 3:m300 s550
4:m300 s550 5:m300 s550 6:m300 s550 7:m300 s550
8:m300 s550 9:m350 s500 10:m350 s500 11:m350 s550
12:m300 s550 13:m300 s1400 14:m300 s550 15:m300 s550
16:m300 s550 17:m300 s550 18:m300 s550 19:m350 s500
20:m350 s550 21:m300 s550 22:m300 s550 23:m300 s1400
24:m300 s550 25:m300 s550 26:m300 s550 27:m300 s550
28:m350 s500 29:m350 s500 30:m350 s550 31:m300 s550
32:m300 s550 33:m300 s550 34:m300 s550 35:m300 s550
36:m300 s550 37:m300 s1400 38:m300 s550 39:m350 s500
40:m350 s550 41:m300 s550 42:m300 s550 43:m300 s550
44:m300 s550 45:m300 s1400 46:m300 s550 47:m300 s1400
48:m350
Extent=51650
Mark min:300 max:350
Space min:500 max:1400
Sent raw
Raw samples(2): Gap:57862
Head: m50 s1800
Extent=1850
Mark min:32767 max:0
Space min:32767 max:0
Sent raw
Show us a good schematic of your circuit. Show us a good image of your wiring.
Attach sketch.
Please use code tags. Use the </> icon in the posting menu. [code] Paste sketch here. [/code]
