IR Receiver Help
Hello all,
I need help with my IR receiver. I have a code to drive a 'car' with a TV remote. I know the code is fine and the library is fine because it was working fine yesterday but now it wont work. I have also tried a sample code that I know works but no luck.
Instead of the small led on the receiver staying off and flashing when receiving a signal it just stays on.
It also doesn't print to the serial monitor anymore.
Is the chip fried? I would think it would do the opposite if it was fried (ie. no led flash)
I only have the one receiver so I can't double check the code either but I'm positive it isn't the issue.
Any help is appreciated.
Thanks.
Without your code and a connection diagram we cannot help.
Please put your code in its own window as seen in other posts. This can be done by placing     [code]  and [/code]  around the code or use the </> icon. This makes it easier for others to read.
How to use this forum
Weedpharma
The code I was trying to test it with is from the Arduino starter kit.
#include <IRremote.h>
#include <IRremoteInt.h>
const int irReceiverPin = 7;
const int ledPin = 13;
IRrecv irrecv(irReceiverPin);
decode_results results;
  pinMode(ledPin,OUTPUT);
  irrecv.enableIRIn();
  if (irrecv.decode(&results))
    Serial.print("irCode: ");
    Serial.print(results.value, HEX);
    Serial.print(",  bits: ");
    Serial.println(results.bits);
    irrecv.resume();
  Serial.print("test");
  delay(600);
  if(results.value == 0x6D0)
    digitalWrite(ledPin,HIGH);
    digitalWrite(ledPin,LOW);
The exact project is here:
Your sketch works perfectly.
You either have a wiring problem or you have damaged your hardware.
Often breadboard wires can be open/intermittent.
Show us a "good" image of your wiring.
