Hi all!
I have built an automatic laser (IR) gun that interacts with the Nerf LaserX guns using an Arduino Nano! I am trying to do it with a ESP32 (Fire-Beetle) but I am having library issues. Does anyone know of a good replacement library for the ESP32? It took forever for me to find suitable libraries just for the Nano, because I need to be able to send and receive raw values.
Code:
#include <IRLibSendBase.h>
#include <IRLibRecv.h>
#include <IRLibDecodeBase.h>
#include <IRLib_HashRaw.h>
#include <IRLibCombo.h>
#include <Servo.h>
//void(* resetFunc) (void) = 0; // create a standard reset function
#define RECV_PIN 11
#define shotLED 8
#define redLED 6
#define yellowLED 5
#define blueLED 7
#define shootingLED 4
Servo servo;
Servo servo2;
IRrecv myReceiver(RECV_PIN);
IRsendRaw mySender;
IRdecode myDecoder;
static const long PURPLE = 0x67228B44;
static const long RED = 0x78653B0E;
static const long BLUE = 0x2FFEA610;
static const long LStar = 0x181FAA50;
// PURPLE
unsigned int rawDataPurple[] = {
2888, 5987, 2893,
2058, 848, 2052, 843, 2069, 795, 2104, 791, // 0, 0, 0, 0
2109, 1816, 2109, 837, 2063, 842, 2057, 848, // 1, 0, 0, 0
2052, 1873, 2055, 840, 2059, 846, 2054, 841, // 1, 0, 0, 0
2071, 794, 2106, 789, 2111, 795, 2105, 841, // 0, 0, 0, 0
1000
// RED
unsigned int rawDataRed[] = {
2899, 5977, 2897,
2065, 842, 2058, 849, 2051, 845, 2055, 842, // 0, 0, 0, 0
2058, 1869, 2056, 851, 2061, 826, 2074, 792, // 1, 0, 0, 0
2108, 789, 2111, 836, 2064, 843, 2057, 840, // 0, 0, 0, 0
2060, 846, 2054, 843, 2057, 850, 2050, 847, // 0, 0, 0, 0
1000
// BLUE
unsigned int rawDataBlue[] = {
2896, 5979, 2902,
2060, 836, 2064, 843, 2057, 848, 2052, 844, // 0, 0, 0, 0
2055, 1870, 2055, 851, 2052, 844, 2065, 820, // 1, 0, 0, 0
2080, 795, 2105, 1821, 2104, 792, 2111, 836, // 0, 1, 0, 0
2063, 843, 2057, 838, 2062, 845, 2055, 840, // 0, 0, 0, 0
1000
int timer;
int timer1;
int timer2;
int maxTimer = 2000;
int shotMax = 5;
int timeoutTime;
int shotAmount;
int myColor;
int shotA;
int pos;
int pos2;
boolean endScan;
boolean endScan2;
boolean startTimer;
myReceiver.enableIRIn(); // Start the receiver
servo.attach(9);
servo2.attach(10);
servo.write(40);
servo2.write(70);
pinMode(shotLED, OUTPUT);
pinMode(redLED, OUTPUT);
pinMode(yellowLED, OUTPUT);
pinMode(blueLED, OUTPUT);
pinMode(shootingLED, OUTPUT);
digitalWrite(shotLED, LOW);
digitalWrite(redLED, LOW);
digitalWrite(yellowLED, LOW);
digitalWrite(blueLED, LOW);
digitalWrite(shootingLED, LOW);
Try:
while (!myReceiver.getResults());
myDecoder.decode();
if(myDecoder.protocolNum==UNKNOWN) {
Serial.print(F("IR recieved. Hash value is: 0x"));
Serial.println(myDecoder.value,HEX);
if (myDecoder.value == PURPLE) {
Serial.println("Purple set!!!!");
myColor = 1;
digitalWrite(yellowLED, HIGH);
else if (myDecoder.value == BLUE) {
Serial.println("BLUE set!!!!");
myColor = 2;
digitalWrite(blueLED, HIGH);
else if (myDecoder.value == RED) {
Serial.println("RED set!!!!");
myColor = 3;
digitalWrite(redLED, HIGH);
else {
Serial.println("Try again...");
goto Try;
for (int p=0;p<=(myColor-1);p++){
digitalWrite(shotLED, HIGH);
servoScan();
// team leds
if (myColor == 1) {
else if (myColor == 2) {
//servo timer
timer++;
if (startTimer == true){
timer1++;
if (timer1 == 2000){
timer1 = 0;
startTimer = false;
maxTimer = 2000;
servo.write(40);
servo2.write(57);
servo2.write(70); //cancel out servo sag
if (timer == maxTimer) {
timer = 0;
Serial.println("Shooting...");
digitalWrite(shootingLED, HIGH);
shoot();
delay(50);
// boost mode
if (myReceiver.getResults()){
Serial.println(myReceiver.getResults());
myDecoder.decode();
//Serial.print(F("IR recieved. Hash value is: 0x"));
delay(20);
if (myDecoder.value == RED && myColor == 3 || myDecoder.value == BLUE && myColor == 2){
boostSet();
timer = 0;
maxTimer = 6;
startTimer = true;
if (myDecoder.value == PURPLE && (myColor == 2 || myColor == 3)){ //reset
delay(4000);
resetFunc();
//normal mode
if (myDecoder.value == PURPLE && myColor == 1) {
shotA++;
if (shotA != 3){
return;
shotA = 0;
Serial.println("Purple hit!!!!");
delay(2000);
shotAmount++;
Serial.println(shotAmount);
if (shotAmount == shotMax){
shotAmount = 0;
for (int i=0;i<=18;i++){
delay(350);
delay(350);
delay(100);
else if (myDecoder.value == BLUE && myColor == 3) {
shotA++;
if (shotA != 3){
return;
shotA = 0;
Serial.println("BLUE hit!!!!");
delay(2000);
shotAmount++;
shotAmount = 0;
delay(350);
delay(350);
delay(100);
else if (myDecoder.value == RED && myColor == 2) {
shotA++;
if (shotA != 3){
return;
shotA = 0;
Serial.println("RED hit!!!!");
delay(2000);
shotAmount++;
shotAmount = 0;
delay(350);
delay(350);
delay(100);
delay(1);
void servoScan(){
//scan servos
//servo1
if (endScan == false){
pos++;
else if (endScan == true){
pos--;
if (pos == 65){
endScan = true;
else if (pos == 15){
endScan = false;
servo.write(pos);
//servo2
if (endScan2 == false){
pos2++;
else if (endScan2 == true){
pos2--;
if (pos2 == 110){
endScan2 = true;
else if (pos2 == 40){
endScan2 = false;
servo2.write(pos2);
delay(4);
void shoot() {
if (myColor == 1){
mySender.send(rawDataPurple, 36, 38);
else if (myColor == 3){
mySender.send(rawDataRed, 36, 38);
else if (myColor == 2){
mySender.send(rawDataBlue, 36, 38);//Pass the buffer,length, optionally frequency
void boostSet(){
Serial.println("Boost charge...");
Error:
Multiple libraries were found for "Servo.h"
Used: /Users/user/Desktop/Arduino/libraries/Servo
/Users/user/Desktop/Arduino/libraries/IRLibRecv/IRLibRecv.cpp:16:12: fatal error: avr/interrupt.h: No such file or directory
Not used: /Applications/Electronics/Arduino.app/Contents/Java/libraries/Servo
#include <avr/interrupt.h>
compilation terminated.
exit status 1
Error compiling for board FireBeetle ESP32-E.
Any suggestions?
Thanks in advance!
