IR Receiver reading only 0's
Hi, I am using an IR Receiver that I've got from Elegoo super starter kit. I am also using an Arduino Uno .I've used this code to decode it to HEX format:
#include <IRremote.h>
const int RECV_PIN = 7;
IRrecv irrecv(RECV_PIN);
decode_results results;
void setup(){
  irrecv.enableIRIn();
  irrecv.blink13(true);
void loop(){
  if (irrecv.decode(&results)){
        Serial.println(results.value, HEX);
        irrecv.resume();
All I get in the serial monitor (9600 baud rate) is 0. I've tried everything including checking if it was dead but it still displayed 0's. Just incase I used my 2nd IR Receiver from my Elegoo sensor kit but yet that also posted 0's. I've searched all over and use every code i could get my hands on but yet it didn't work. I've even tried using an Arduino Nano, esp8266, Elegoo Arduino Uno &, off branded Nano. I even bought more IR Receivers but they don't work ether...
links:
Elegoo super starter kit:
Elegoo sensor kit:
IR Receiver:
https://www.amazon.ca/Gikfun-Infrared-Emission-Receiver-Electronic/dp/B07FFQ9B9H/ref=sr_1_1_sspa?crid=1IZE1GOSPN3ZA&dchild=1&keywords=ir+receiver&qid=1611691825&sprefix=ir+re%2Caps%2C323&sr=8-1-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUE0QUwxN05WV1JJWFImZW5jcnlwdGVkSWQ9QTA3MTMzMzYxNTg1VllIUFlDWDVGJmVuY3J5cHRlZEFkSWQ9QTA2MjM1NTIzNUM2VFQyVVo1RDNLJndpZGdldE5hbWU9c3BfYXRmJmFjdGlvbj1jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ==
I'VE FOUND A SOLUTION!
Turns out this code is a working code:
#include <IRremote.h> //Make sure to install the library
int IRpin=9;
IRrecv IR(IRpin);
decode_results cmd;
String myCom;
IR.enableIRIn();
  while (IR.decode(&cmd)==0){
Serial.println(cmd.value,HEX);
delay(1500);
IR.resume();
if (cmd.value==0xFF6897){
  myCom="zero";
  Serial.println(myCom);
if (cmd.value==0xFFA25D){
  myCom="pwr";
But I did install the wrong Library . Turns out I needed to get an older version because the newest version of this libeary is different. I downloaded the 2.2.3 version and it worked!
Here is the link to the Library you should download instead:
Or just download it directly here.
Thank you SO MUCH for this solution. I have been banging my head against the wall trying to get something beside "0". The older version of IRreceiver worked great ! ! ! ! !
The older (and newest) versions of the IRremote library are available through the IDE library manager. Always use the library manager to install libraries, if possible.
