Hey all, I'm using an IR receiver to control the PWM output (for motor control)...just like the topic says.
I have an LED set up to pin 10 just for testing purposes, but I can't seem to get an output voltage (even connected a multimeter).
The IR receiver is doing it's job, and it's outputting a result; however, I can't seem to get that result to translate to a PWM value.
Please check out my code and let me know what I'm doing wrong. It compiles fine without problems; just doesn't work.
The PWM programming starts near the bottom of the code at the /////////////////////
Thanks
int ir_pin = 2; //Sensor pin 1 wired through a 220 ohm resistor
int led_pin = 13; //"Ready to Recieve" flag, not needed but nice
int debug = 0; //Serial connection must be started to debug
int start_bit = 2000; //Start bit threshold (Microseconds)
int bin_1 = 1000; //Binary 1 threshold (Microseconds)
int bin_0 = 400; //Binary 0 threshold (Microseconds)
pinMode(led_pin, OUTPUT); //This shows when we're ready to recieve
pinMode(ir_pin, INPUT);
digitalWrite(led_pin, LOW); //not ready yet
int key = getIRKey(); //Fetch the key
Serial.print("Key Recieved: ");
Serial.println(key);
int getIRKey() {
int data[12];
digitalWrite(led_pin, HIGH); //Ok, i'm ready to recieve
while(pulseIn(ir_pin, LOW) < 2200) { //Wait for a start bit
data[0] = pulseIn(ir_pin, LOW); //Start measuring bits, I only want low pulses
data[1] = pulseIn(ir_pin, LOW);
data[2] = pulseIn(ir_pin, LOW);
data[3] = pulseIn(ir_pin, LOW);
data[4] = pulseIn(ir_pin, LOW);
data[5] = pulseIn(ir_pin, LOW);
data[6] = pulseIn(ir_pin, LOW);
data[7] = pulseIn(ir_pin, LOW);
data[8] = pulseIn(ir_pin, LOW);
data[9] = pulseIn(ir_pin, LOW);
data[10] = pulseIn(ir_pin, LOW);
data[11] = pulseIn(ir_pin, LOW);
if(debug == 1) {
Serial.println("-----");
for(int i=0;i<11;i++) { //Parse them
if (debug == 1) {
Serial.println(data[i]);
if(data[i] > bin_1) { //is it a 1?
data[i] = 1;
if(data[i] > bin_0) { //is it a 0?
data[i] = 0;
data[i] = 2; //Flag the data as invalid; I don't know what it is!
for(int i=0;i<11;i++) { //Pre-check data for errors
if(data[i] > 1) {
return -1; //Return -1 on invalid data
int result = 0;
int seed = 1;
for(int i=0;i<11;i++) { //Convert bits to integer
if(data[i] == 1) {
result += seed;
seed = seed * 2;
return result; //Return key number
int motor_pin = 10; // define the pin which will send the motor commands
int motor_input = result;
void setup ();
pinMode (motor_pin, OUTPUT);
void loop ();
analogWrite(motor_pin,motor_input); //uses PWM of Arduino to change motor speed.
Serial.println(motor_input);
