IR receiver with strange repeat codes.
I'm getting some confusing codes being received by my IR receiver.
I've hooked up IRRecvdemo from the IR library, and it works fine. I've found that the buttons that I want to use correspond to FD5AA5 and FDD827. If I hold down a button I get FFFFFFFF, but Google tells me that this is a repeat code, and normal.
OK so far.
I've adjusted the code to turn an LED on and off. Sweet! Works fine.
I added some more code to move a servo. It works sometimes. Which is really frustrating.
Sometimes the servo moves. But sometimes it doesn't. Serial monitor shows me that sometimes new button presses are being received as FFFFFFFF, which I haven't coded for anything, and even more confusingly, random HEX codes which are neither repeat codes nor command codes are being received (4AB0F7B7, 4CB0FADD).
#include <IRremote.h>
#include <Servo.h>
const int servoPin = 4;
Servo servo;
int RECV_PIN = 11;
int angle = 90;
int change = 5;
IRrecv irrecv(RECV_PIN);
decode_results results;
  servo.attach(servoPin);
  irrecv.enableIRIn(); // Start the receiver---
  if (irrecv.decode(&results)) {
    Serial.println(results.value, HEX);
    if (results.value==0xFD5AA5){//left button
            digitalWrite(13,HIGH);
            angle = angle + change;
    if (results.value==0xFDD827){//this is the RIGHT button
      digitalWrite(13,LOW);
      angle = angle - change;
angle = constrain(angle, 10, 170);
servo.write(angle);
      irrecv.resume(); // Receive the next value
  //delay(100);
If I block out the parts to do with servo, the LEDs work fine. On with one button, off with the other.
           // angle = angle + change;
      //angle = angle - change;
//angle = constrain(angle, 10, 170);
//servo.write(angle);
  //delay(100);
Please help. I think the servo is interacting strangely with something; I can get LEDs to blink with my remote but the servo ruining everything.
Tell us how you have the servo connected. A picture may help.
Weedpharma
