IR receiver
This is a simple Ifrared Remote receiver for use where
only the code sent is required.
Connect your IR receiver to +5v and earth and signal
to digital 2.
It blocks until a The IR receives a command of any type.
If the command is valid. That is 16 bits or 4 hex digits
sent at 38 kHz it exits with the command value.
This is the NEC IR transmission protocol.
It works for most common remotes.
Typical outputs from 3 different IRs.
First two hex are address,next two for command.
FFCF
FF67
FFB7
B12D
B1EF
B1CF
FEE7
FE57
FEB7
Find at:GitHub - carl47/arduino-projects-carl47: arduino-projects-carl47
