ir receiving and sending to turn on and off tv
hi everyone,
I try to write a sketch to receive the power button from my tv remote control, then I use the receiving signal to send to turn on and off my tv. My sketch is successfully receive and send to turn on and off my tv. however, when I add this function:
irrecv.enableIRIn();
to decode the different button.
then my tv can't turn on and off anymore even through I see the same signal from my oscilloscope with or without this function irrecv.enableIRIn();
only this line in my sketch cause trouble: irrecv.enableIRIn();
when I comment it out, then everything works normal.
anyone has any idea what's the problem? if you need to see my code, i'll post it later.
Thanks in advance !!!
sonh:
I think people will need to see your code to help.
Pointing the remote at the Arduino instead of the TV doesn't make sense, unless there is more that the Arduino is supposed to do.
Here is my code. I tried to simplify my previous code a bit. Whole purpose of my sketch is to turn on and turn off tv every 10s. And I also want to decode and print any buttons being pressed. I noticed that every time I enable " irrecv.enableIRIn(); " line, then my sketch stop execute. It does not matter where I place this function " irrecv.enableIRIn(); " it always stop execute when I enable it.
any ideas would be great appreciated !!!
#include <IRremote.h>
#define IRpin_PIN      PIND
#define IRpin          2
#define MAXPULSE 65000
#define RESOLUTION 20
IRrecv irrecv(IRpin);
decode_results results;
uint32_t PowerKeyCode = 0;
uint16_t pulses[100][2];
uint8_t currentpulse = 0;
int IRledPin =  13;
int LedPin = 3;
  pinMode(IRledPin, OUTPUT);
  pinMode(LedPin, OUTPUT);
  Serial.println("Ready to decode remote control power key!");
  digitalWrite (LedPin, HIGH);
  for (int i=0; i < 100; i++) PowerKey();
  digitalWrite (LedPin, LOW);
// start main loop
/*   if (irrecv.decode(&results))
      Serial.println(results.value, DEC); // Print the Serial 'results.value'
      irrecv.resume();   // Receive the next value
    printpulses;
    SendChannelUpCode();  // turn on tv
    delay (10000);
    SendChannelUpCode();  // turn off tv
// start sending 38khz signal inside the IR pulsewidth envelope function
 void pulseIR(long microsecs)
  cli();
  while (microsecs > 0)
      digitalWrite(IRledPin, HIGH);
      delayMicroseconds(10);
      digitalWrite(IRledPin, LOW);
      microsecs -= 26;
  sei();
// start IR transmitting function
 void SendChannelUpCode()
  for (int i=0; i <100; i++)
   { delayMicroseconds(pulses [i][0] * RESOLUTION);
     pulseIR(pulses [i][1] * RESOLUTION);
// start reading remote control function for power key.
 void PowerKey()
  uint16_t highpulse, lowpulse;
  highpulse = lowpulse = 0;
   while (IRpin_PIN & (1 << IRpin))
     highpulse++;
     delayMicroseconds(RESOLUTION);
     if ((highpulse >= MAXPULSE) && (currentpulse != 0))
       printpulses();
       currentpulse=0;
       return;
  pulses[currentpulse][0] = highpulse;
   while (! (IRpin_PIN & _BV(IRpin)))
       lowpulse++;
       if ((lowpulse >= MAXPULSE)  && (currentpulse != 0))
         printpulses();
         currentpulse=0;
         return;
   pulses[currentpulse][1] = lowpulse;
   currentpulse++;
// start printing function
 void printpulses(void)
    Serial.println("\n\r\n\rReceived: \n\rOFF \tON");
    for (uint8_t i = 0; i < currentpulse; i++)
    Serial.print(pulses[i][0] * RESOLUTION, DEC);
    Serial.print(" usec, ");
    Serial.print(pulses[i][1] * RESOLUTION, DEC);
    Serial.println(" usec");
// end printing function
Which Arduino are you using this code on? How much memory do you still have free? That 800 byte array pulses just may not be possible.
    printpulses;
This should be:
    42;
hi PaulS,
I am using UNO with Atmega32. When I printpulsed through serial port and I see they all print out fine with 100 pairs. These 100 pairs turn on and off my tv successful all the time without adding this line: irrecv.enableIRIn();
whenever I enable: irrecv.enableIRIn(); it stops transmitting.
Thanks for your help !!!
hi everyone,
I need your help to give me your advise how to fix the bug in my code. I did not get much help so far !!!
any ideas would be appreciated !!!
What does your code look like now? Have you fixed the printpulses; issue? How?
hi PaulS,
no, I did not fix the printpulses; because I see it print out through serial without problem. I am using UNO with atmega32. By the way, the printpulses just the information for me to see. I can disable this function anytime I want. My real problem with the irrecv.enableIRIn(); function. Every time I enable this function, my sketch stop running. I can tell it stops because no print data through serial port anymore.
when I disable this irrecv.enableIRIn(); function, everything works normal. it print out 100 pairs and turn on and off tv in 10 seconds apart.
here is the message I got when I compile my sketch:
Sketch uses 3,574 bytes (11%) of program storage space. Maximum is 32,256 bytes.
Global variables use 891 bytes (43%) of dynamic memory, leaving 1,157 bytes for local variables. Maximum is 2,048 bytes.
based on the compiler message, memory still available, am i right?
can you help to point out where the problem is? Thanks so much !!!
